Page 3 of 3 1 2 3
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2319749
06/12/17 09:35 AM
06/12/17 09:35 AM
Virginia
JimG Offline
JimG  Offline
Virginia
I bought a tank from Rock Valley for my '67 Coronet. They fabricate many tanks for EFI from scratch but given the odd shape of the '66-'67 B-body tank, they modify a Spectra tank for this application. They did a nice job, creating a chamber inside the tank that the pump slips into. I've never had any starvation issues with a low level. It also uses a vertical street rod sending unit that is far more accurate than the aftermarket unit I was using when the car had a carb. My only complaint is that I had to cut a hole in my trunk floor and get a small sheetmetal "hump" fabricated to cover it. Again, that might be unique to the '66-'67 B-body. Honestly though, I would have done this anyway... nothing like having to drop the tank if the fuel pump goes Tango Uniform far away from home. I'm running a Walbro LPH400 pump. Being in the tank, even that particular pump, which is one of the louder in-tank pumps, is way quieter than the Carter electric pump I was using when the car was carbureted.
Check out this thread. You'll have to weed though a bunch of Megasquirt discussion, but eventually the discussion gets heavily into the Tanks Inc setup.
http://www.dodgecharger.com/forum/index.php/topic,99432.0.html
I'm attaching a few pics of my talk. I bought this over 4 years ago and I'm sure there are many more options today.
Best of luck!
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2323906
06/19/17 11:32 PM
06/19/17 11:32 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
I just pulled my tank out again.
I have a Walbro Electric pump in the tank. It is a GSS342 pump that produces 255 lph.
Two other friends got basically the same tank, one for a 70 Challenger and another for a 72 'Cuda and they both had the same pump.
So I do not know where the other info came from.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2323920
06/19/17 11:58 PM
06/19/17 11:58 PM
BDW Online content
BDW  Online Content
Finally got my FiTech with Spectra tank install up and running.
Car runs great so far.............
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2324630
06/21/17 12:06 PM
06/21/17 12:06 PM
The Netherlands, OV
dickdale Offline OP
dickdale  Offline OP
The Netherlands, OV
awesome! Which Fitech Efi do you use?
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2324895
06/21/17 08:13 PM
06/21/17 08:13 PM
BDW Online content
BDW  Online Content
I picked up the 600HP model when they had the $100 rebate this last Christmas.
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2325799
06/23/17 04:21 PM
06/23/17 04:21 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Originally Posted By dickdale
Originally Posted By denfireguy
On my Ebody, I have had the Tanks and the Spectra EFI tanks.
Spectra all the way.
Which EFI did you use?
Using a Megasquirt 2 controlling a Holley Terminator throttle body. Was also using a PWM controller for the Walbro pump but found out Walbro does not recommend using pump controllers. I am back using a mechanical regulator.
It is pretty well dialed in with the exception of IAC and secondary injector tip in. Enjoying the car now, this stuff will be adjusted later.
Craig
Re: in tank fuel pump Fitech Efi [Re: dickdale] #2325875
06/23/17 07:45 PM
06/23/17 07:45 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
If you have fab skills and want a low budget approach- go to the junkyard and pick up a steel fuel tank from an early 90's Ford Explorer. The pump/ tank flange, hanger and vent can be re-used, and if your careful you can reuse the sump (antislosh) from the Explorer tank. The hanger will mate up with a Walbro pump with some mods.
Page 3 of 3 1 2 3
