De-stroked 5.7
#2311394
05/26/17 08:35 AM
05/26/17 08:35 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
I have guy who retired from my work last year who is building a Plymouth street rod, he wants to build a smaller 5.7 or 4.7 Cammer. We were talking about the G3 hemi and he asked if I know if anyone had built a de-stroked 5.7 , I thought I came across a thread in my internet lurking about someone wanting to build a long rod 5.7 and had to de-stroke down to 3.48 or 3.4ish? I was wondering if anyone know who it was or if they had heard of anyone doing this... Thanks
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
Re: De-stroked 5.7
[Re: ric3xrt]
#2311467
05/26/17 12:16 PM
05/26/17 12:16 PM
ric3xrt
Trumbauersville PA
He says(his words not mine) he wants to keep power down but wants the look of a modern mopar engine. he's even thinking about the 3.5 or 3.7 V6s , light back end, no traction control, doesn't want it to be a handful. he had a 23 T bucket with a stock 5.7 and that was a handful. this car is a Plymouth roadster , no fenders, no top type nostalgic. I've searched around and I don't see any piston or rod combo that works with out custom work. . offset grind the crank and then build the journal back up to a 2.2 pin and use BBchevy rods ...which makes no sense at all
Re: De-stroked 5.7
[Re: ric3xrt]
#2311474
05/26/17 12:25 PM
05/26/17 12:25 PM
ric3xrt
Trumbauersville PA
I told him last night I think he's better off with a 4.7, but he wants to go with a carb, I suggested that he try and see if a MSD Hemi 6 would work on the 4.7 , I've seen guys use the 4.7 PCM on 5.7s why couldn't he go the other way.
Re: De-stroked 5.7
[Re: ric3xrt]
#2311572
05/26/17 03:03 PM
05/26/17 03:03 PM
ric3xrt
Trumbauersville PA
Kool , I'll send him in that direction. Thanks
Re: De-stroked 5.7
[Re: ric3xrt]
#2312426
05/28/17 03:25 PM
05/28/17 03:25 PM
ric3xrt
Trumbauersville PA
Seems like a very expensive way to go. If he is going to use a carb anyway, why not just limit the ability to WOT? Or restrict plate, or gearing.... I suggested a Plate, and it might get one, who knows I bought a set of rods last night for the build off ebay, $200, I gave him a 6.1 crank to use, so he's only out the shop bill, and the pistons, are going to be stock 5.7s out of the 30k 04 motor he already has.
Re: De-stroked 5.7
[Re: GTS340]
#2312786
05/29/17 07:40 AM
05/29/17 07:40 AM
ric3xrt
Trumbauersville PA
What rods did you get? How are you handling the wrist pins? Found a set of Eagle CRs6300HJ on ebay with a buy it now of $200, Pins are .927, so we'll have to use some after market pistons, instead of the stockers(which to me is a good thing)
Re: De-stroked 5.7
[Re: WO23Coronet]
#2312788
05/29/17 07:49 AM
05/29/17 07:49 AM
ric3xrt
Trumbauersville PA
Even if he destrokes it I don't think it'll help. It still has awesome flowing heads and will make the hp, just at a higher rpm. It will kill abit of low end torque but not enough to really make a difference in a 2400 lb (?) vehicle I agree , and I don't think it's not going to achieve his objective.....but he's convinced that a high centerline cam and single plane intake will move the torque up enough to make it more street able , while a 650/700 CFM carb will help with throttle response.
Re: De-stroked 5.7
[Re: killermopar]
#2313666
05/30/17 05:18 PM
05/30/17 05:18 PM
dogdays
For sure he doesn't want to go 4.7.
You say build back up to bigblock chevy rod journal size. The GIII Hemi has rod journals that are nearly the same as a SBM, why go any larger?
I guess "destroked" sounds cool to the guy. I'd limit power with an adjustable throttle stop. The old "bolt under the gas pedal."
R.
Re: De-stroked 5.7
[Re: dogdays]
#2338259
07/17/17 11:18 AM
07/17/17 11:18 AM
ric3xrt
Trumbauersville PA
R. The idea with build up the journal was to use an Aftermarket 6.38 Rod. it was just an Idea, his money to spend not mine.
Re: De-stroked 5.7
[Re: Stewart]
#2338261
07/17/17 11:20 AM
07/17/17 11:20 AM
ric3xrt
Trumbauersville PA
I have a couple unused Callies cranks. 2.93 stroke and 14 Carillo rods. Also have an ATI damper. The cranks were cut on the snout for dry sump so a spacer would have to be made for the pump drive. Some trouble but I would sell the crank, 8 rods and the damper for $750 + shipping. The damper would need a different center or the existing one cut to remove the dry sump pump belt drive. Was for a 305 project that never went forward. Stewart pm me on a price for the Callies crank. We went with a 4.7 engine out of a Dakota
