De-stroked 5.7 #2311394
05/26/17 08:35 AM
05/26/17 08:35 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
I have guy who retired from my work last year who is building a Plymouth street rod, he wants to build a smaller 5.7 or 4.7 Cammer.
We were talking about the G3 hemi and he asked if I know if anyone had built a de-stroked 5.7 , I thought I came across a thread in my internet lurking about someone wanting to build a long rod 5.7 and had to de-stroke down to 3.48 or 3.4ish? I was wondering if anyone know who it was or if they had heard of anyone doing this...
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: De-stroked 5.7 [Re: ric3xrt] #2311455
05/26/17 11:51 AM
05/26/17 11:51 AM
USA
hudsonhornet7x Offline
USA
Rick there was a gentleman here last year who had a de-stroked crank for a gen III for sale. That is all I remember of it though. May I ask why he wants such a small engine?
Re: De-stroked 5.7 [Re: ric3xrt] #2311467
05/26/17 12:16 PM
05/26/17 12:16 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
He says(his words not mine) he wants to keep power down but wants the look of a modern mopar engine. he's even thinking about the 3.5 or 3.7 V6s , light back end, no traction control, doesn't want it to be a handful. he had a 23 T bucket with a stock 5.7 and that was a handful.
this car is a Plymouth roadster , no fenders, no top type nostalgic.
I've searched around and I don't see any piston or rod combo that works with out custom work. . offset grind the crank and then build the journal back up to a 2.2 pin and use BBchevy rods ...which makes no sense at all
Re: De-stroked 5.7 [Re: ric3xrt] #2311474
05/26/17 12:25 PM
05/26/17 12:25 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
I told him last night I think he's better off with a 4.7, but he wants to go with a carb, I suggested that he try and see if a MSD Hemi 6 would work on the 4.7 , I've seen guys use the 4.7 PCM on 5.7s why couldn't he go the other way.
Re: De-stroked 5.7 [Re: ric3xrt] #2311485
05/26/17 12:37 PM
05/26/17 12:37 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
6.300 Honda journal SBC rod
1.220 CH piston
3.48 stroke
Would leave piston slightly above deck, not a bad thing if using early 5.7 heads
Re: De-stroked 5.7 [Re: ric3xrt] #2311572
05/26/17 03:03 PM
05/26/17 03:03 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Kool , I'll send him in that direction.
Re: De-stroked 5.7 [Re: ric3xrt] #2312349
05/28/17 12:29 PM
05/28/17 12:29 PM
tri-cities Washington/Denver, ...
5280Dart Offline
5280Dart  Offline
Seems like a very expensive way to go.
If he is going to use a carb anyway, why not just limit the ability to WOT? Or restrict plate, or gearing....
Re: De-stroked 5.7 [Re: ric3xrt] #2312426
05/28/17 03:25 PM
05/28/17 03:25 PM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
I suggested a Plate, and it might get one, who knows
I bought a set of rods last night for the build off ebay, $200, I gave him a 6.1 crank to use, so he's only out the shop bill, and the pistons, are going to be stock 5.7s out of the 30k 04 motor he already has.
Re: De-stroked 5.7 [Re: ric3xrt] #2312449
05/28/17 04:23 PM
05/28/17 04:23 PM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
What rods did you get? How are you handling the wrist pins?
Re: De-stroked 5.7 [Re: ric3xrt] #2312525
05/28/17 06:52 PM
05/28/17 06:52 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
Even if he destrokes it I don't think it'll help. It still has awesome flowing heads and will make the hp, just at a higher rpm. It will kill abit of low end torque but not enough to really make a difference in a 2400 lb (?) vehicle
Re: De-stroked 5.7 [Re: GTS340] #2312786
05/29/17 07:40 AM
05/29/17 07:40 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Found a set of Eagle CRs6300HJ on ebay with a buy it now of $200,
Pins are .927, so we'll have to use some after market pistons, instead of the stockers(which to me is a good thing)
Re: De-stroked 5.7 [Re: WO23Coronet] #2312788
05/29/17 07:49 AM
05/29/17 07:49 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
I agree , and I don't think it's not going to achieve his objective.....but he's convinced that a high centerline cam and single plane intake will move the torque up enough to make it more street able , while a 650/700 CFM carb will help with throttle response.
Re: De-stroked 5.7 [Re: ric3xrt] #2313528
05/30/17 01:20 PM
05/30/17 01:20 PM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
Use a stock engine and a really high gear. That's what I would do. But it sounds interesting. Wondering what it will make.
Re: De-stroked 5.7 [Re: killermopar] #2313666
05/30/17 05:18 PM
05/30/17 05:18 PM
dogdays Offline
dogdays  Offline
For sure he doesn't want to go 4.7.
You say build back up to bigblock chevy rod journal size. The GIII Hemi has rod journals that are nearly the same as a SBM, why go any larger?
I guess "destroked" sounds cool to the guy. I'd limit power with an adjustable throttle stop. The old "bolt under the gas pedal."
R.
Re: De-stroked 5.7 [Re: ric3xrt] #2323923
06/20/17 12:01 AM
06/20/17 12:01 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
I have a couple unused Callies cranks. 2.93 stroke and 14 Carillo rods. Also have an ATI damper. The cranks were cut on the snout for dry sump so a spacer would have to be made for the pump drive. Some trouble but I would sell the crank, 8 rods and the damper for $750 + shipping. The damper would need a different center or the existing one cut to remove the dry sump pump belt drive.
Was for a 305 project that never went forward.
Re: De-stroked 5.7 [Re: dogdays] #2338259
07/17/17 11:18 AM
07/17/17 11:18 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
R.
The idea with build up the journal was to use an Aftermarket 6.38
Rod.
it was just an Idea, his money to spend not mine.
Re: De-stroked 5.7 [Re: Stewart] #2338261
07/17/17 11:20 AM
07/17/17 11:20 AM
Trumbauersville PA
ric3xrt Offline OP
ric3xrt  Offline OP
Trumbauersville PA
Stewart pm me on a price for the Callies crank.
We went with a 4.7 engine out of a Dakota
Re: De-stroked 5.7 [Re: ric3xrt] #2340195
07/20/17 09:47 AM
07/20/17 09:47 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
just pull timing out in the lower gears... shruggy
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
