#2311394 - 05/26/17 06:35 AM De-stroked 5.7
ric3xrt Offline
Loc: Trumbauersville PA
I have guy who retired from my work last year who is building a Plymouth street rod, he wants to build a smaller 5.7 or 4.7 Cammer.
We were talking about the G3 hemi and he asked if I know if anyone had built a de-stroked 5.7 , I thought I came across a thread in my internet lurking about someone wanting to build a long rod 5.7 and had to de-stroke down to 3.48 or 3.4ish? I was wondering if anyone know who it was or if they had heard of anyone doing this...
Truth has no agenda, but those with an agenda don't always acknowledge truth
74 D100 D-Code,3x75 D100 D-code, 3x77 D100 D-code,6x78 D150 D-D-code...lots of pre 81 trucks
75 4x2 Ramcharger....G3 coming soon
2003 Ram st
2004 Rumble Bee
2004 Ram GTX(Plum Crazy)
2005 Ram GTXtreme(s Plum Crazy,Banana Yellow)
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building)
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
#2311455 - 05/26/17 09:51 AM Re: De-stroked 5.7 [Re: ric3xrt]
hudsonhornet7x Offline
Loc: Plumer, Pa
Rick there was a gentleman here last year who had a de-stroked crank for a gen III for sale. That is all I remember of it though. May I ask why he wants such a small engine?
XP29H8B198192
#2311467 - 05/26/17 10:16 AM Re: De-stroked 5.7 [Re: ric3xrt]
ric3xrt Offline
He says(his words not mine) he wants to keep power down but wants the look of a modern mopar engine. he's even thinking about the 3.5 or 3.7 V6s , light back end, no traction control, doesn't want it to be a handful. he had a 23 T bucket with a stock 5.7 and that was a handful.
this car is a Plymouth roadster , no fenders, no top type nostalgic.
I've searched around and I don't see any piston or rod combo that works with out custom work. . offset grind the crank and then build the journal back up to a 2.2 pin and use BBchevy rods ...which makes no sense at all
Edited by ric3xrt (05/26/17 10:25 AM)
2003 Ram st
2004 Rumble Bee
#2311474 - 05/26/17 10:25 AM Re: De-stroked 5.7 [Re: ric3xrt]
ric3xrt Offline
I told him last night I think he's better off with a 4.7, but he wants to go with a carb, I suggested that he try and see if a MSD Hemi 6 would work on the 4.7 , I've seen guys use the 4.7 PCM on 5.7s why couldn't he go the other way.
2003 Ram st
2004 Rumble Bee
#2311485 - 05/26/17 10:37 AM Re: De-stroked 5.7 [Re: ric3xrt]
GTS340 Offline
Loc: Romulus, MI
6.300 Honda journal SBC rod
1.220 CH piston
3.48 stroke
Would leave piston slightly above deck, not a bad thing if using early 5.7 heads
#2311572 - 05/26/17 01:03 PM Re: De-stroked 5.7 [Re: ric3xrt]
ric3xrt Offline
Kool , I'll send him in that direction.
2003 Ram st
2004 Rumble Bee
#2312349 - 05/28/17 10:29 AM Re: De-stroked 5.7 [Re: ric3xrt]
5280Dart Offline
Loc: tri-cities Washington/Denver, ...
Seems like a very expensive way to go.
If he is going to use a carb anyway, why not just limit the ability to WOT? Or restrict plate, or gearing....
#2312426 - 05/28/17 01:25 PM Re: De-stroked 5.7 [Re: ric3xrt]
ric3xrt Offline
I suggested a Plate, and it might get one, who knows
I bought a set of rods last night for the build off ebay, $200, I gave him a 6.1 crank to use, so he's only out the shop bill, and the pistons, are going to be stock 5.7s out of the 30k 04 motor he already has.
2003 Ram st
2004 Rumble Bee
#2312449 - 05/28/17 02:23 PM Re: De-stroked 5.7 [Re: ric3xrt]
GTS340 Offline
Loc: Romulus, MI
What rods did you get? How are you handling the wrist pins?
#2312525 - 05/28/17 04:52 PM Re: De-stroked 5.7 [Re: ric3xrt]
WO23Coronet Offline
Loc: Canada
Even if he destrokes it I don't think it'll help. It still has awesome flowing heads and will make the hp, just at a higher rpm. It will kill abit of low end torque but not enough to really make a difference in a 2400 lb (?) vehicle
#2312786 - 05/29/17 05:40 AM Re: De-stroked 5.7 [Re: GTS340]
ric3xrt Offline
Found a set of Eagle CRs6300HJ on ebay with a buy it now of $200,
Pins are .927, so we'll have to use some after market pistons, instead of the stockers(which to me is a good thing)
2003 Ram st
2004 Rumble Bee
#2312788 - 05/29/17 05:49 AM Re: De-stroked 5.7 [Re: WO23Coronet]
ric3xrt Offline
I agree , and I don't think it's not going to achieve his objective.....but he's convinced that a high centerline cam and single plane intake will move the torque up enough to make it more street able , while a 650/700 CFM carb will help with throttle response.
2003 Ram st
2004 Rumble Bee
#2313528 - 05/30/17 11:20 AM Re: De-stroked 5.7 [Re: ric3xrt]
killermopar Offline
Loc: Spencer NY
Use a stock engine and a really high gear. That's what I would do. But it sounds interesting. Wondering what it will make.
#2313666 - 05/30/17 03:18 PM Re: De-stroked 5.7 [Re: killermopar]
dogdays Offline
For sure he doesn't want to go 4.7.
You say build back up to bigblock chevy rod journal size. The GIII Hemi has rod journals that are nearly the same as a SBM, why go any larger?
I guess "destroked" sounds cool to the guy. I'd limit power with an adjustable throttle stop. The old "bolt under the gas pedal."
R.
Edited by dogdays (05/30/17 03:20 PM)
#2323923 - 06/19/17 10:01 PM Re: De-stroked 5.7 [Re: ric3xrt]
Stewart Offline
Loc: Loganville, GA
I have a couple unused Callies cranks. 2.93 stroke and 14 Carillo rods. Also have an ATI damper. The cranks were cut on the snout for dry sump so a spacer would have to be made for the pump drive. Some trouble but I would sell the crank, 8 rods and the damper for $750 + shipping. The damper would need a different center or the existing one cut to remove the dry sump pump belt drive.
Was for a 305 project that never went forward.
#2338259 - 07/17/17 09:18 AM Re: De-stroked 5.7 [Re: dogdays]
ric3xrt Offline
R.
The idea with build up the journal was to use an Aftermarket 6.38
Rod.
it was just an Idea, his money to spend not mine.
2003 Ram st
2004 Rumble Bee
#2338261 - 07/17/17 09:20 AM Re: De-stroked 5.7 [Re: Stewart]
ric3xrt Offline
Stewart pm me on a price for the Callies crank.
We went with a 4.7 engine out of a Dakota
2003 Ram st
2004 Rumble Bee
#2340195 - 07/20/17 07:47 AM Re: De-stroked 5.7 [Re: ric3xrt]
OUTLAWD Offline
Loc: Plymouth, MI
just pull timing out in the lower gears... shruggy
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - FITech test rig...
25,260 Registered Members
189,048 Topics
Cylinder bottom chamfer
by DGS
4 minutes 15 seconds ago
Gear vendors electronic speed sensor
by DGS
19 minutes 38 seconds ago
Drag radials, adjustable suspension, manual transmission.
by OhioMopar
23 minutes 5 seconds ago
WIW complete ac system from /6 71 Duster?
by moparjoe360.4
Today at 01:03 AM
