Re: edelbrock victor ?
[Re: moparmafia]
#226915
02/16/09 06:36 PM
02/16/09 06:36 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I can tell you right now Victors and Indy 440-1's will not go 400.
Looks like stealth's are the best bang for the buck. I hear they go 320-330 range. Not to bad for $1900.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#226916
02/16/09 06:52 PM
02/16/09 06:52 PM
Posts: 4,243 Canada
Kam*Kuda
Canada
I don't think the stealth heads are in the same league as the victors or SR's I hear good things about the voctors but have not run them. I am looking at the EZ so I do not have to get other rocker arms
1970 Barracuda Convertible 1968 Satellite Street Strip car 1654.5 Mustang 1955 Land Rover
[Re: moparmafia]
#226922
02/16/09 08:04 PM
02/16/09 08:04 PM
Posts: 31,050 Oregon
AndyF
I don't understand your statement about making the most power you can. What does that mean? Put a blower and run nitro if you want to make power. Since you're using a production block you're limited to something in the 700-800 hp range. The Indy EZ heads can easily make that kind of power and you won't have to mess around with offset rocker arms or raised port headers. There is this book you need to read . . .
[Re: moparmafia]
#226925
02/16/09 08:29 PM
02/16/09 08:29 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
of course everyone wants to make the most power they can. that was just a general statement, i thought you could understand that. ok i will try this again. i want to make the most power i can make with a 400 block stroked to 500. so what head would you use? victor, -1, or sr. or ?
I understood what you meant. You want to make the most power you can with those choice of heads. Its sort of a toss up. All three flow virtually the same..fully ported. But the best one out of the box has been the Victor. But I think you are talking about fully ported flow which= most horsepower. So it comes down to your personal choice. Each of these heads is a slightly different flavor of the same dish. The SR has better exhaust flow than the EZ. The Victor uses a bigger intake valve and should make slightly more power than either of those. So, of the heads you mentioned, IMHO, the Victor and the 440-1 would make the most power. Do you lke Edlebrock or ICH, thats pretty much the choice you will have to make.
[Re: moparmafia]
#226928
02/16/09 09:16 PM
02/16/09 09:16 PM
Posts: 3,619 Norwich CT USA
Defbob
Norwich CT USA
If you want to make a lot of power with a low deck motor then run B1 heads. The B1 heads are designed for low decks and they'll make a lot more power than Victor heads.
http://www.b1heads.com/
[Re: Defbob]
#226930
02/16/09 09:26 PM
02/16/09 09:26 PM
Defbob
Norwich CT USA
The B1's are my personal favorite Wedge head. They are the last heads you'd ever need. period and they look cool with the matching intake (Best Machines motor)
[Re: moparmafia]
#226931
02/16/09 09:34 PM
02/16/09 09:34 PM
AndyF
who should i contact about b1 heads and what stroker kit will i have to buy? doesn't the b1 heads use different pistons, rockers and headers? if the sr's cnc ported can make 800 hp what would the b1 heads make?
http://b1heads.com/
[Re: Harley]
#226934
02/17/09 11:41 AM
02/17/09 11:41 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I gotta agree with the B1 stuff. The 440-1;s would be a distant second. I went with the 440-1's maxed out on power, had about as much money in to them as B1's would have been. And probably 50-100HP less.
Its been proven that the B1 stuff runs pretty good with just some prep work, no need to go all out. Yes its more money, but how much money will you spend later, changing the whole combo?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparmafia]
#226938
02/17/09 03:25 PM
02/17/09 03:25 PM
B1Fish540
Flint, Michigan
i already have the headers and rockers and i was trying to figure if it would be worth going to the b1 heads. i know the sr's flow 355 but i had heard somewhere the victors would be quite a bit more. i would love to have the b1's but not sure i would want to spend that much.
IMO, if you already have the headers and rockers from a stock head then you go with the EZs. On the B1s, I would not use them on a stock block...they make too much power. I know its done all the time, but 900 or 1000 hp in a stock block scares me...lol
[Re: B1Fish540]
#226939
02/17/09 03:35 PM
02/17/09 03:35 PM
BDS871Cuda
I agree Fish! Why would you spend all that money in B1 stuff and put it on a stock block.
I really think Stealth's CNC'd by MCH could put a stock block to the test.
They say over 700+.
[Re: BDS871Cuda]
#226940
02/17/09 03:52 PM
02/17/09 03:52 PM
B1Fish540
Flint, Michigan
They say over 700+.
Thats true, BDS, 700hp is stretching it for a stock block but he should be OK, IMHO. Besides, the Stealths can be used with his stock headers and rockers..so they would definitely be a good choice for a low buck and powerful combo. The EZs would make quite a bit more power..but the costs would be alot more too.
[Re: moparmafia]
#226942
02/18/09 03:18 AM
02/18/09 03:18 AM
Posts: 43,228 Bend,OR USA
Cab_Burge
I've made 700 HP with a 518 C.I. 910.25 to 1 comp. ratio low deck with MCH CNC Eddy RPM on pump gas, I will(hopefully) be dyno testing a 527 C.I. 12.4 to 1 comp ratio 440 bock with SR heads with max wedge ports soon. Hopefully in the next three weeks if everything at the dyno shop goes okay I will post the results, my Eddy heads flowed 310 CFM at 28 inches at .600 lift, my SR flowed 340 CFM at .600 lift at 28 inches on the same bench on two different days months apart. The 527 has more cam also and it will be tested on race gas I hope it doesn't break on the dyno and make a mess and embarrass me
