Re: edelbrock victor ?
[Re: Harley]
#226934
02/17/09 11:41 AM
02/17/09 11:41 AM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
I gotta agree with the B1 stuff. The 440-1;s would be a distant second. I went with the 440-1's maxed out on power, had about as much money in to them as B1's would have been. And probably 50-100HP less.
Its been proven that the B1 stuff runs pretty good with just some prep work, no need to go all out. Yes its more money, but how much money will you spend later, changing the whole combo?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: moparmafia]
#226938
02/17/09 03:25 PM
02/17/09 03:25 PM
Posts: 2,840 Flint, Michigan
B1Fish540
Flint, Michigan
i already have the headers and rockers and i was trying to figure if it would be worth going to the b1 heads. i know the sr's flow 355 but i had heard somewhere the victors would be quite a bit more. i would love to have the b1's but not sure i would want to spend that much.
IMO, if you already have the headers and rockers from a stock head then you go with the EZs. On the B1s, I would not use them on a stock block...they make too much power. I know its done all the time, but 900 or 1000 hp in a stock block scares me...lol ![](/ubbthreads/images/graemlins/shock.gif)
[Re: B1Fish540]
#226939
02/17/09 03:35 PM
02/17/09 03:35 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
I agree Fish! Why would you spend all that money in B1 stuff and put it on a stock block.
I really think Stealth's CNC'd by MCH could put a stock block to the test.
They say over 700+.
Snap your neck, mega G-force launch, is all I want!
[Re: BDS871Cuda]
#226940
02/17/09 03:52 PM
02/17/09 03:52 PM
B1Fish540
Flint, Michigan
They say over 700+.
Thats true, BDS, 700hp is stretching it for a stock block but he should be OK, IMHO. Besides, the Stealths can be used with his stock headers and rockers..so they would definitely be a good choice for a low buck and powerful combo. The EZs would make quite a bit more power..but the costs would be alot more too.
[Re: moparmafia]
#226942
02/18/09 03:18 AM
02/18/09 03:18 AM
Posts: 43,303 Bend,OR USA
Cab_Burge
I've made 700 HP with a 518 C.I. 910.25 to 1 comp. ratio low deck with MCH CNC Eddy RPM on pump gas, I will(hopefully) be dyno testing a 527 C.I. 12.4 to 1 comp ratio 440 bock with SR heads with max wedge ports soon. Hopefully in the next three weeks if everything at the dyno shop goes okay ![](/ubbthreads/images/graemlins/luck.gif) I will post the results, my Eddy heads flowed 310 CFM at 28 inches at .600 lift, my SR flowed 340 CFM at .600 lift at 28 inches on the same bench on two different days months apart. ![](/ubbthreads/images/graemlins/shruggy.gif) The 527 has more cam also and it will be tested on race gas ![](/ubbthreads/images/graemlins/shruggy.gif) I hope it doesn't break on the dyno and make a mess and embarrass me ![](/ubbthreads/images/graemlins/luck.gif)
