Re: edelbrock victor ? [Re: Harley] #226934
02/17/09 11:41 AM
02/17/09 11:41 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
I gotta agree with the B1 stuff. The 440-1;s would be a distant second. I went with the 440-1's maxed out on power, had about as much money in to them as B1's would have been. And probably 50-100HP less.
Its been proven that the B1 stuff runs pretty good with just some prep work, no need to go all out. Yes its more money, but how much money will you spend later, changing the whole combo?
Re: edelbrock victor ? [Re: Bob_Coomer] #226935
02/17/09 11:54 AM
02/17/09 11:54 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Don't you have to buy special pistons to run b-1's ?
Re: edelbrock victor ? [Re: moparmafia] #226936
02/17/09 11:55 AM
02/17/09 11:55 AM
Colorado
506RR Offline
506RR  Offline
Colorado
If you don't have headers, or rockers yet, then I would go with the 440-1's or the Victors. That way you have room to grow with them in the future. Either head is capable of making quite a bit more power than a stock block can handle.
If you already have headers for a stock port location and standard roller rockers, then a set of EZ heads CNC'd by Jeff at Modern would be the hot ticket like AndyF said.
I have a set of EZ heads and a set of SR heads that have been CNC'd by Jeff, and both flow right at 350 cfm on the intakes, but the SR's outflow the EZ's on the exhaust by about 20-30 cfm.
Re: edelbrock victor ? [Re: 506RR] #226937
02/17/09 03:17 PM
02/17/09 03:17 PM
Ky
moparmafia Offline OP
Ky
i already have the headers and rockers and i was trying to figure if it would be worth going to the b1 heads. i know the sr's flow 355 but i had heard somewhere the victors would be quite a bit more. i would love to have the b1's but not sure i would want to spend that much.
Re: edelbrock victor ? [Re: moparmafia] #226938
02/17/09 03:25 PM
02/17/09 03:25 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
IMO, if you already have the headers and rockers from a stock head then you go with the EZs. On the B1s, I would not use them on a stock block...they make too much power. I know its done all the time, but 900 or 1000 hp in a stock block scares me...lol
Re: edelbrock victor ? [Re: B1Fish540] #226939
02/17/09 03:35 PM
02/17/09 03:35 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I agree Fish!
Why would you spend all that money in B1 stuff
and put it on a stock block.
I really think Stealth's CNC'd by MCH could put
a stock block to the test.
They say over 700+.
Snap your neck, mega G-force launch, is all I want!
Re: edelbrock victor ? [Re: BDS871Cuda] #226940
02/17/09 03:52 PM
02/17/09 03:52 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I agree Fish!
They say over 700+.
Thats true, BDS, 700hp is stretching it for a stock block but he should be OK, IMHO. Besides, the Stealths can be used with his stock headers and rockers..so they would definitely be a good choice for a low buck and powerful combo. The EZs would make quite a bit more power..but the costs would be alot more too.
Re: edelbrock victor ? [Re: B1Fish540] #226941
02/17/09 09:50 PM
02/17/09 09:50 PM
BigFish69 Offline
BigFish69  Offline
Keep buying those China Stealth heads and you maybe looking for a job to go along with those heads.
Re: edelbrock victor ? [Re: moparmafia] #226942
02/18/09 03:18 AM
02/18/09 03:18 AM
I've made 700 HP with a 518 C.I. 910.25 to 1 comp. ratio low deck with MCH CNC Eddy RPM on pump gas, I will(hopefully) be dyno testing a 527 C.I. 12.4 to 1 comp ratio 440 bock with SR heads with max wedge ports soon. Hopefully in the next three weeks if everything at the dyno shop goes okay I will post the results, my Eddy heads flowed 310 CFM at 28 inches at .600 lift, my SR flowed 340 CFM at .600 lift at 28 inches on the same bench on two different days months apart. The 527 has more cam also and it will be tested on race gas I hope it doesn't break on the dyno and make a mess and embarrass me
