edelbrock victor ? #226914
02/16/09 06:29 PM
02/16/09 06:29 PM
Ky
moparmafia Offline OP
Ky
has anyone ran the victors yet? i am trying to decide if i want the 440-1, sr's or the victors. i dont know anyone that has run a set but i had heard before these were going to be the best bang for the buck. is it true they can flow 400 cfm? from all the heads out there the sr still seems the best for the money.any info would be greatly appreciated.
Re: edelbrock victor ? [Re: moparmafia] #226915
02/16/09 06:36 PM
02/16/09 06:36 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
I can tell you right now Victors and Indy 440-1's
will not go 400.
Looks like stealth's are the best bang for the buck. I hear they go 320-330 range.
Not to bad for $1900.
Snap your neck, mega G-force launch, is all I want!
Re: edelbrock victor ? [Re: BDS871Cuda] #226916
02/16/09 06:52 PM
02/16/09 06:52 PM
Canada
Kam*Kuda Online content
Kam*Kuda  Online Content
Canada
I don't think the stealth heads are in the same league as the victors or SR's
I hear good things about the voctors but have not run them. I am looking at the EZ so I do not have to get other rocker arms
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: edelbrock victor ? [Re: moparmafia] #226917
02/16/09 07:23 PM
02/16/09 07:23 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I have em with porting they will go 350 but you have to buy offset intake rocker arms, no way will the stealths flow that, there in the 275 out of the box. like the rpm.
I think stock 906's were around 225cfm
Re: edelbrock victor ? [Re: 70blackfish] #226918
02/16/09 07:42 PM
02/16/09 07:42 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
I would use the Victors long before using Indy
Re: edelbrock victor ? [Re: moparmafia] #226919
02/16/09 07:44 PM
02/16/09 07:44 PM
AndyF Offline
AndyF  Offline
How much power are you trying to make and what is the shortblock? The Victor heads are okay but I'm not so sure they are a great bang for the buck by the time you add up the extras.
Personally I think the CNC ported Indy EZ heads are probably the best bet for most guys. They'll make 800 hp on a 500 inch shortblock and you don't need a special header or expensive offset rocker arms.
Re: edelbrock victor ? [Re: AndyF] #226920
02/16/09 07:59 PM
02/16/09 07:59 PM
Ky
Ky
i am going with a 400 stroked to 500 with 440 source kit. i want to make the most power i can and if the victors are quite a bit more hp than sr's then i would go with them. i havent seen any information on a fully ported set of victors to help make up my mind.
Re: edelbrock victor ? [Re: moparmafia] #226921
02/16/09 08:01 PM
02/16/09 08:01 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
you dont need 400 cfm
Re: edelbrock victor ? [Re: moparmafia] #226922
02/16/09 08:04 PM
02/16/09 08:04 PM
AndyF Offline
AndyF  Offline
I don't understand your statement about making the most power you can. What does that mean? Put a blower and run nitro if you want to make power.
Since you're using a production block you're limited to something in the 700-800 hp range. The Indy EZ heads can easily make that kind of power and you won't have to mess around with offset rocker arms or raised port headers.
There is this book you need to read . . .
Re: edelbrock victor ? [Re: AndyF] #226923
02/16/09 08:08 PM
02/16/09 08:08 PM
Riverside, Ca
G_bob Offline
G_bob  Offline
Riverside, Ca
Check back in a week or so. We'll all know then what the victors make on my 505 build.
Victor 505 build <--- Click here
Re: edelbrock victor ? [Re: AndyF] #226924
02/16/09 08:10 PM
02/16/09 08:10 PM
Ky
Ky
of course everyone wants to make the most power they can. that was just a general statement, i thought you could understand that. ok i will try this again. i want to make the most power i can make with a 400 block stroked to 500. so what head would you use? victor, -1, or sr. or ?
Re: edelbrock victor ? [Re: moparmafia] #226925
02/16/09 08:29 PM
02/16/09 08:29 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I understood what you meant. You want to make the most power you can with those choice of heads. Its sort of a toss up. All three flow virtually the same..fully ported. But the best one out of the box has been the Victor. But I think you are talking about fully ported flow which= most horsepower. So it comes down to your personal choice. Each of these heads is a slightly different flavor of the same dish. The SR has better exhaust flow than the EZ. The Victor uses a bigger intake valve and should make slightly more power than either of those. So, of the heads you mentioned, IMHO, the Victor and the 440-1 would make the most power. Do you lke Edlebrock or ICH, thats pretty much the choice you will have to make.
Re: edelbrock victor ? [Re: moparmafia] #226926
02/16/09 08:51 PM
02/16/09 08:51 PM
AndyF Offline
AndyF  Offline
If you want to make a lot of power with a low deck motor then run B1 heads. The B1 heads are designed for low decks and they'll make a lot more power than Victor heads.
Re: edelbrock victor ? [Re: AndyF] #226927
02/16/09 09:03 PM
02/16/09 09:03 PM
Ky
Ky
who should i contact about b1 heads and what stroker kit will i have to buy? doesn't the b1 heads use different pistons, rockers and headers? if the sr's cnc ported can make 800 hp what would the b1 heads make?
Re: edelbrock victor ? [Re: moparmafia] #226928
02/16/09 09:16 PM
02/16/09 09:16 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
http://www.b1heads.com/
Re: edelbrock victor ? [Re: moparmafia] #226929
02/16/09 09:26 PM
02/16/09 09:26 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
yes. Original B1s flow about 415 cfm. 900 hp is pretty easy. You may end up spending $1000 extra over the 440-1/Intake package for the B1 Package, though.
Re: edelbrock victor ? [Re: Defbob] #226930
02/16/09 09:26 PM
02/16/09 09:26 PM
Norwich CT USA
Defbob Offline
Defbob  Offline
Norwich CT USA
The B1's are my personal favorite Wedge head.
They are the last heads you'd ever need. period
and they look cool with the matching intake (Best Machines motor)
Re: edelbrock victor ? [Re: moparmafia] #226931
02/16/09 09:34 PM
02/16/09 09:34 PM
AndyF Offline
AndyF  Offline
http://b1heads.com/
Re: edelbrock victor ? [Re: moparmafia] #226932
02/17/09 08:46 AM
02/17/09 08:46 AM
LOWELL IN
Q
QWK_ENUF Offline
QWK_ENUF  Offline
Q
LOWELL IN
https://board.moparts.org/ubbthreads/show...&PHPSESSID=
i like mine
i just used the offset intakes from hughes like $30 each
clearanceing the head for pushrod was simple and easy
mine are out the box
best of 10.13@130 with no tuning in 3235 lbs duster
WAXER
Re: edelbrock victor ? [Re: QWK_ENUF] #226933
02/17/09 10:41 AM
02/17/09 10:41 AM
Queens, New York
Harley Offline
Harley  Offline
Queens, New York
Dose the B1-BS head have a raised exhaust port like the Indy-SR head?
