Re: trick flow 240 VS. Perf. r.p.m. port molds.
[Re: 67_Satellite]
#2260116
02/26/17 10:04 PM
02/26/17 10:04 PM
Posts: 1,022 Andrews,In. U.S.of A.
67_Satellite
If someone more computer savvy than I wants to convert the links to pics, feel free to do so.We speculated that the 270 head would probably just stick a max wedge inlet on the intake manifold side of the port.
[Re: BradH]
#2260354
02/27/17 11:08 AM
02/27/17 11:08 AM
Posts: 1,051 The Great White North
RAMM
Seriouslt considering these heads for this years EMC build. Now I'm not so sure I see anything worth it. I've seen 2 builds, 1 local to me that @ 446 cubes struggled to make 600HP. I'm thinking ported E-heads are probably just as good and a bit cheaper. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
[Re: 67_Satellite]
#2260509
02/27/17 02:38 PM
02/27/17 02:38 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I might be way out in left field, but I kinda feel like the smaller exhaust valve, along with the smallish exhaust port on the TF head is not really the hot ticket for big power.
[Re: 67_Satellite]
#2260570
02/27/17 04:35 PM
02/27/17 04:35 PM
Posts: 1,237 North Central, Indiana
Roughbird72
Btw, on 67_Satellite's bench the ootb flow numbers on 1 chamber.
Intake 319.3 @ .650 Exhaust 263.4 @ .650
He did check an intake on another chamber and I believe it was slightly more than 320.
72 Plymouth Roadrunner 11.08@123.25
[Re: Roughbird72]
#2260586
02/27/17 05:13 PM
02/27/17 05:13 PM
fast68plymouth
So. Burlington, Vt.
I assume the exhaust number was achieved using some sort of flow tube.
