trick flow 240 VS. Perf. r.p.m. port molds. #2260108
02/26/17 09:58 PM
02/26/17 09:58 PM
Andrews,In. U.S.of A.
67_Satellite Offline OP
http://i355.photobucket.com/albums/r461/FriedDonuts/port%20mold_zpsbotjhqo8.jpg Made some port molds earlier this winter of my performer R.P.M. port and Bubby 440'S new trick flow 240 port. Mine have been mildly ported and are 220c.c. vs. I think 215 c.c. stock.Looks like most of the increased area is in an improved bowl area. Minimum cross section at the pinch is the same.Edelbrock on top t.f. on bottom.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260110
02/26/17 10:00 PM
02/26/17 10:00 PM
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260116
02/26/17 10:04 PM
02/26/17 10:04 PM
If someone more computer savvy than I wants to convert the links to pics, feel free to do so.We speculated that the 270 head would probably just stick a max wedge inlet on the intake manifold side of the port.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260171
02/26/17 11:26 PM
02/26/17 11:26 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
wave
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: slantzilla] #2260338
02/27/17 10:32 AM
02/27/17 10:32 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Going by the TF CSA measurements in the picture above, that is a much tighter "pinch" in the flow path than I expected.
Now I'm wondering how much of this still exists in their new 270 MW head. Trick Flow's decision not to use offset intake rockers certainly limits the capability to address this.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: BradH] #2260354
02/27/17 11:08 AM
02/27/17 11:08 AM
The Great White North
RAMM Offline
RAMM  Offline
Seriouslt considering these heads for this years EMC build. Now I'm not so sure I see anything worth it. I've seen 2 builds, 1 local to me that @ 446 cubes struggled to make 600HP. I'm thinking ported E-heads are probably just as good and a bit cheaper. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260385
02/27/17 12:05 PM
02/27/17 12:05 PM
Idaho
LaRoy Engines Offline
Idaho
I'd like to see you go with the Trick Flow but the RPM heads are capable of some pretty remarkable performance.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260509
02/27/17 02:38 PM
02/27/17 02:38 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I might be way out in left field, but I kinda feel like the smaller exhaust valve, along with the smallish exhaust port on the TF head is not really the hot ticket for big power.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260570
02/27/17 04:35 PM
02/27/17 04:35 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Btw, on 67_Satellite's bench the ootb flow numbers on 1 chamber.
Intake 319.3 @ .650
Exhaust 263.4 @ .650
He did check an intake on another chamber and I believe it was slightly more than 320.
72 Plymouth Roadrunner 11.08@123.25
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: Roughbird72] #2260586
02/27/17 05:13 PM
02/27/17 05:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
Intake 319.3 @ .650
I assume the exhaust number was achieved using some sort of flow tube.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: fast68plymouth] #2260616
02/27/17 05:59 PM
02/27/17 05:59 PM
Yes,it was.About 1.875" X 8" long.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260642
02/27/17 07:00 PM
02/27/17 07:00 PM
BradH Offline
BradH  Offline
What did you use to make those port molds? They came out really well.
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260669
02/27/17 08:19 PM
02/27/17 08:19 PM
K
KOS Offline
KOS  Offline
K
how did the eddy compare in flow???
Re: trick flow 240 VS. Perf. r.p.m. port molds. [Re: 67_Satellite] #2260742
02/27/17 10:50 PM
02/27/17 10:50 PM
OOMOO 30 is the silicone compound I got off of ebay to make the molds.Two parts mix 50/50. There is also a spray on mold release agent, which I highly suspect is silicone lube spray in a $9 can. It takes some force to remove it from the port. I found that by sticking a large Sharpie 3/4 of the way down the middle of the intake gasket side to create a void,the rubber could "collapse" partially and ease removal.
The Edelbrock heads maxed out at 305 c.f.m. at .500" and stayed flat after that. They have a 2.200 valve with a 30 deg. seat. The goal was to maximize low and mid flow. Pushrod pinch has been opened and they got a general smoothing and straightening treatment. O.O.T.B. flow numbers were in the high 280's,right about the same as Edelbrocks advertised numbers.
