Aluminum Weld W/O a tig
#216528
02/07/09 11:23 AM
02/07/09 11:23 AM
Posts: 2,709 NJ central
Scamp408
NJ central
Re: Aluminum Weld W/O a tig
[Re: gamagoat6x6]
#216531
02/07/09 05:14 PM
02/07/09 05:14 PM
Posts: 420 Central Ohio
Ledman_70
Central Ohio
I got suckered into buying a pound of something similar a few years ago at a swapmeet for $25. Looked like miracle stuff after the guy welded up a quarter inch hole in a Coke can. I have tried to use it on several things and can't get it to stick to ANYTHING!
Jeff Adams
64 426 Polara
[Re: gamagoat6x6]
#216532
02/07/09 05:20 PM
02/07/09 05:20 PM
Posts: 18,425 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
I watched a guy sticking some aluminum beer cans together with similar rods years ago at Carlisle. We tried to break them apart later and couldn`t do it. Good stuff.
The trick is in the quality. Pop and beer cans for human consumption. They are pure aluminum with no impurities. A quallity alloy welds very easy. Another important part is the tip size and heat. Those guys that put on the show have it down to a science.
[Re: NITROUSN]
#216533
02/07/09 05:31 PM
02/07/09 05:31 PM
Posts: 3,897 Oregon
hooziewhatsit
A friend of mine has used that stuff for a little while now. He's making a canopy for his boat, and connecting the crossbeams to aluminum tube on either end. He said the trick is to tin each piece, then attach them. Also make sure the joints get up to a good temperature, THEN add the weld/solder/whatever you call it. -Dave
[Re: hooziewhatsit]
#216534
02/07/09 05:34 PM
02/07/09 05:34 PM
Posts: 20,187 Park Forest, IL
slantzilla
Park Forest, IL
I've seen some guys use it, but they were pretty good welders to start with. I think I'd argue the claim that it is better than a TIG also.
[Re: Scamp408]
#216535
02/07/09 08:21 PM
02/07/09 08:21 PM
Posts: 1,475 Ontario, Canada
78D150CLUB
My avatar is a self portrait!!
Ontario, Canada
Similar product. http://www.muggyweld.com/I plan on trying it to close up drilled holes in an otherwise clean and straight grille work.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
