Aluminum Weld W/O a tig #216528
02/07/09 11:23 AM
02/07/09 11:23 AM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
Did anyone ever try this stuff?
http://www.aluminumrepair.com/?src=google&gclid=CK_wlLTbypgCFQFvGgodSVoB1g
Looks like good stuff.
Re: Aluminum Weld W/O a tig [Re: Scamp408] #216529
02/07/09 12:07 PM
02/07/09 12:07 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
that does look like good stuff you wouldn't think brazing rod would be that strong. that's cool
Re: Aluminum Weld W/O a tig [Re: dirtybee] #216530
02/07/09 01:12 PM
02/07/09 01:12 PM
Alone in the darkness
gamagoat6x6 Offline
super street
gamagoat6x6  Offline
super street
I watched a guy sticking some aluminum beer cans together with similar rods years ago at Carlisle. We tried to break them apart later and couldn`t do it. Good stuff.
`02 RAM2500 SPORT V10 4x4 `06 GMC sierra NO cars
Re: Aluminum Weld W/O a tig [Re: gamagoat6x6] #216531
02/07/09 05:14 PM
02/07/09 05:14 PM
Central Ohio
Ledman_70 Offline
Ledman_70  Offline
Central Ohio
I got suckered into buying a pound of something similar a few years ago at a swapmeet for $25. Looked like miracle stuff after the guy welded up a quarter inch hole in a Coke can. I have tried to use it on several things and can't get it to stick to ANYTHING!
Jeff Adams 64 426 Polara
Re: Aluminum Weld W/O a tig [Re: gamagoat6x6] #216532
02/07/09 05:20 PM
02/07/09 05:20 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The trick is in the quality. Pop and beer cans for human consumption. They are pure aluminum with no impurities. A quallity alloy welds very easy. Another important part is the tip size and heat. Those guys that put on the show have it down to a science.
Re: Aluminum Weld W/O a tig [Re: NITROUSN] #216533
02/07/09 05:31 PM
02/07/09 05:31 PM
hooziewhatsit Offline
A friend of mine has used that stuff for a little while now. He's making a canopy for his boat, and connecting the crossbeams to aluminum tube on either end.
He said the trick is to tin each piece, then attach them. Also make sure the joints get up to a good temperature, THEN add the weld/solder/whatever you call it.
-Dave
Re: Aluminum Weld W/O a tig [Re: hooziewhatsit] #216534
02/07/09 05:34 PM
02/07/09 05:34 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I've seen some guys use it, but they were pretty good welders to start with.
I think I'd argue the claim that it is better than a TIG also.
Re: Aluminum Weld W/O a tig [Re: Scamp408] #216535
02/07/09 08:21 PM
02/07/09 08:21 PM
Ontario, Canada
78D150CLUB Offline
My avatar is a self portrait!!
78D150CLUB  Offline
Ontario, Canada
Similar product.
http://www.muggyweld.com/
I plan on trying it to close up drilled holes in an otherwise clean and straight grille work.
I want to die like my Grampa, peacefully, in his sleep. Not screaming in terror like his passengers.
Re: Aluminum Weld W/O a tig [Re: 78D150CLUB] #216536
02/07/09 10:02 PM
02/07/09 10:02 PM
NJ central
Scamp408 Offline OP
Scamp408  Offline OP
NJ central
I was looking at the muggy but it doesnt have the high temp like the other.
