BB Mopar Crank Options #2164453
09/29/16 04:04 PM
09/29/16 04:04 PM
Pennsylvania
shantyshakinstud Offline OP
Pennsylvania
Was informed by Callies yesterday that they have discontinued making BB Mopar Crankshafts, other than Billet. They informed me they have sold their last stock of Magnum/Dragon Slayer to Indy.
Any other options out there in-between a Chinese crank or a $3000+ billet deal?
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164459
09/29/16 04:11 PM
09/29/16 04:11 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Callies says this every few years to get the racers nervous and to go out and spend on one. I think Indy has a lot to do with this.
I doubt this is true.
You will see Callies Mopar cranks again, I guarantee.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164470
09/29/16 04:28 PM
09/29/16 04:28 PM
AndyF Offline
AndyF  Offline
There are plenty of options, just depends on what you need and how big your budget is. SCAT has the internal capability to do a lot of stuff with raw forgings so you can get almost anything from them. SCAT builds stroker cranks with Honda journals and stuff like that which nobody else offers. On my last project I worked with a crank engineer at SCAT and he had the ability to design most anything I wanted as long as it fit into the confines of their rough forging.
If you aren't looking for anything that exotic then Molnar provides really nice high quality cranks made from off shore forgings.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164488
09/29/16 04:51 PM
09/29/16 04:51 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Not personal but I've read good things about Molnar.
Boffin Emeritus
Re: BB Mopar Crank Options [Re: polyspheric] #2164496
09/29/16 04:58 PM
09/29/16 04:58 PM
Pennsylvania
Pennsylvania
Nothing too crazy, 4.150 stroke with BB Mopar size journals.
Naturally Aspirated truck puller, so it sees sustained rpm in the 7500-8000 rpm range.
Callies did say "billet is way overkill" when I called.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164497
09/29/16 05:01 PM
09/29/16 05:01 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Molnar x2
Mine sees a lot of street and strip abuse.
'63 Dodge 330
11.19 @ 121 mph
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164523
09/29/16 05:54 PM
09/29/16 05:54 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
so what aftermarket block do you have lined up for these "7500-8000 rpm" pulls?
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164527
09/29/16 06:03 PM
09/29/16 06:03 PM
Washington
madscientist Offline
Washington
I would skip the BB MoPar journals. Get a cranks with BBC throws and be done with it.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164534
09/29/16 06:13 PM
09/29/16 06:13 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
440Source
Been 150mph in the 1/8 with an out of the box 440Source crank. It's been in the car 3 years.
Re: BB Mopar Crank Options [Re: FastmOp] #2164540
09/29/16 06:19 PM
09/29/16 06:19 PM
Pennsylvania
Pennsylvania
Its a Koleno Block, been running the combination for a lot of years, just thinking I should be looking at a crank upgrade next time its apart and was shocked to find what Callies told me, and even more shocked when I looked at a Crower/Bryant pricing and availability.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164576
09/29/16 06:51 PM
09/29/16 06:51 PM
On your deal, substained high RPM under WOT load, I would make sure the crank has the center counterweights and buy the best material you can get. I like and use Ohio Crankshaft Company (800-333-7113) BB Mopar stroker cranks since 1998 with no failures or come backs up scope They will grind any combination you ask for including making you a billet steel fully counter weighted crankshaft that will be good up to 3000+ HP thumbs I haven't needed or used any of those type yet but they are available work
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164623
09/29/16 08:00 PM
09/29/16 08:00 PM
Mooresburg, Tn
'72CudaRacer Offline
Mooresburg, Tn
Molnar in mine. Very pleased with it.
Brian Dunnigan
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164639
09/29/16 08:26 PM
09/29/16 08:26 PM
Pennsylvania
Pennsylvania
Thanks for your input everyone. I had heard about center counterweights but didnt know where to start inquiring after what Callies told me. I saw Ohio Crank offered a billet hemi crank for $1700 but wondered if i could get it with flywheel locating ring instead of flat snout.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164676
09/29/16 09:00 PM
09/29/16 09:00 PM
Worst Weather USA
493_DART Offline
493_DART  Offline
Worst Weather USA
ive beat on a 4.15 440 source crank for about 8 years now----no problems.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164740
09/29/16 10:36 PM
09/29/16 10:36 PM
Ohio Crankshaft CO. will finish thier custom ground stroker cranks any way you want them. All the forged steel stroker cranks I've bought(15+) from them came with the stock 8 bolt 1/2 inch 426 Street Hemi pattern on the flanges with the locating ring built in, not the earlier 392 top fuel patterns with no locating ring built into the crankshafts up All the other aftermarket wedge motor forged steel stroker cranks I've bought and used had the standard 383/440 six bolt pattern 7/16 bolt size on the flanges shruggy
BTW, Keith Black Enterprises,562-869-1518 sells press in locating rings to use on the top fuel type cranks to use a torque converter in them up I've two or more bracket motors out there using the old top fuel cranks with those locating rings in them with no problems so far thumbs shruggy
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164913
09/30/16 02:59 AM
09/30/16 02:59 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Crower is a great alternative and make center counterweight pieces
Re: BB Mopar Crank Options [Re: Al_Alguire] #2164957
09/30/16 07:00 AM
09/30/16 07:00 AM
gregsdart Offline
gregsdart  Offline
I bought a Crower center weighted crank with 440 size mains and rods, 4.15 stroke, made of 304M I believe? Cost $2300 back in 2010. Beautifully machined balancing on the counter weights, not drilled.
I had some cap walk issues on my cross bolted Megablock. They went away when I upgraded to the center counter weights.
Re: BB Mopar Crank Options [Re: shantyshakinstud] #2164980
09/30/16 09:43 AM
09/30/16 09:43 AM
Nashville, Tennessee
Tempest Offline
Tempest  Offline
Bryant.
Re: BB Mopar Crank Options [Re: Tempest] #2165014
09/30/16 11:32 AM
09/30/16 11:32 AM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Originally Posted By Tempest
Bryant.
There's a name i haven't heard in awhile.
72 Plymouth Roadrunner 11.08@123.25
Re: BB Mopar Crank Options [Re: 493_DART] #2165061
09/30/16 12:43 PM
09/30/16 12:43 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
at 7500-8000 rpm for extended periods like the OP??? smile
