UPDATE: Green Bearing install question
#2160523
09/23/16 11:31 PM
09/23/16 11:31 PM
Posts: 3,344 Central TX
roe
Central TX
Hi all. I'm about to install some bearings and reinstall my axles. When I bought my supplies I forgot to order the foam gaskets. Can I make the from something else. If so, what? Also what should I use to lube the shafts as I press on the bearings and the collar? Wheel bearings grease? Trans fluid?
1971 Plymouth Satellite 408/904 8 3/4 3.23 SG
Re: Bearing install question
[Re: roe]
#2160549
09/23/16 11:56 PM
09/23/16 11:56 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
Any gasket material will work,
Pack the bearing with grease, But the press on collar should be dry with no lube
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: moparts]
#2160556
09/24/16 12:02 AM
09/24/16 12:02 AM
roe
Central TX
Sorry. Should've mentioned green bearings. I'll update the title. Please, no green vs tapered arguments. UPDATE: excuse me for being such a putz. I completely blanked on the fact that they bearing kit already had the gasket in there with the new retainer plate.
[Re: roe]
#2161453
09/25/16 04:24 PM
09/25/16 04:24 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I always spray a small amount of penetrating oil like WD40 on the axle to keep the bearing from galling when I press it on. I install the retainer collar dry. Done hundreds of them this way with never an issue. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2175348
10/15/16 05:53 PM
10/15/16 05:53 PM
roe
Central TX
Everything went together really smoothly. I hadn't done the green bearings before or the adjustable tapered rear bearings. I'd only done tapered bearings on the front end. I'd read here that the greens are pretty easy. After talking to drdiff who sent me a simple step by step I finished it all up. Car is rolling again and all is good. I decided not to run inner bearing seals. Don't know if it's true or not but I figure allowing the diff fluid to touch the sealed bearing should keep them cooler.
roe
