UPDATE: Green Bearing install question #2160523
09/23/16 11:31 PM
09/23/16 11:31 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Hi all. I'm about to install some bearings and reinstall my axles. When I bought my supplies I forgot to order the foam gaskets. Can I make the from something else. If so, what?
Also what should I use to lube the shafts as I press on the bearings and the collar? Wheel bearings grease? Trans fluid? shruggy
1971 Plymouth Satellite
408/904 8 3/4 3.23 SG
Re: Bearing install question [Re: roe] #2160549
09/23/16 11:56 PM
09/23/16 11:56 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Any gasket material will work,
Pack the bearing with grease, But the press on collar should be dry with no lube
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
Re: Bearing install question [Re: moparts] #2160556
09/24/16 12:02 AM
09/24/16 12:02 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Sorry. Should've mentioned green bearings. I'll update the title. Please, no green vs tapered arguments. tsk
UPDATE: excuse me for being such a putz. I completely blanked on the fact that they bearing kit already had the gasket in there with the new retainer plate.
Re: Bearing install question [Re: roe] #2160564
09/24/16 12:12 AM
09/24/16 12:12 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Press in dry
Don't be the exception.
Re: Bearing install question [Re: roe] #2160569
09/24/16 12:15 AM
09/24/16 12:15 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
With green Bearings, Warming KY works well, LOL Sorry couldn't resist, troll beer
Re: Bearing install question [Re: TJP] #2160574
09/24/16 12:18 AM
09/24/16 12:18 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
laugh2
Re: Bearing install question [Re: roe] #2161177
09/25/16 01:45 AM
09/25/16 01:45 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Does this look right to you? If you look at the area between the bearing and the retainer plate there looks like there is about 1/4 of an inch there where the bearing could continue to go forward but it won't. The bearing collar is on as well. No matter if I press from behind the bearing or behind the bearing collar it doesn't budge. I believe it's on as far as it can go but would like your opinions. This is my fist time pressing on bearings. I'm using a harbor freight 20 ton press.
Re: Bearing install question [Re: roe] #2161200
09/25/16 03:24 AM
09/25/16 03:24 AM
Central TX
roe Offline OP
roe  Offline OP
Central TX
I think it's good to go. Last pics posted was passenger side. This one is driver side. It's stops at the same point and I used two different methods to press on each side. Passenger side I did collar and bearing together. This side I did the bearing and collar seperately. They both stop at the same point. Passenger side bearing is slightly harder to turn but I think it's still within what should be normal resistance.
Re: Bearing install question [Re: roe] #2161453
09/25/16 04:24 PM
09/25/16 04:24 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I always spray a small amount of penetrating oil like WD40 on the axle to keep the bearing from galling when I press it on.
I install the retainer collar dry.
Done hundreds of them this way with never an issue.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Bearing install question [Re: fourgearsavoy] #2175348
10/15/16 05:53 PM
10/15/16 05:53 PM
Central TX
roe Offline OP
roe  Offline OP
Central TX
Everything went together really smoothly. I hadn't done the green bearings before or the adjustable tapered rear bearings. I'd only done tapered bearings on the front end. I'd read here that the greens are pretty easy. After talking to drdiff who sent me a simple step by step I finished it all up. Car is rolling again and all is good. I decided not to run inner bearing seals. Don't know if it's true or not but I figure allowing the diff fluid to touch the sealed bearing should keep them cooler.
roe
