4-SPEED REVERSE LOCKOUT TRANS #2143433
08/29/16 10:37 PM
08/29/16 10:37 PM
Ormond Beach, FL
71STROKERFISH Offline OP
Ormond Beach, FL
I've procured a complete 4 speed set up for my 71 Barracuda. My plans are to convert the auto 727 SB to a 4 speed. Everything is used and I can confirm, I've got 90% of everything, my question is the shifter/rods.
Check out the pics I've attached to this message. I called Brewer's Performance today and they stated, it's a Super Competition Reverse lockout shifter.
Has anyone used this on a stock application? I've questioned the seller, and he got it from someone that promised it came out of an AAR.....can't seem to beleive that, but....what are your thoughts? It shifts fine, out of the car as depicted, but I know should be about one shifter height lower, and attached right to the trans on an aluminum block....I've had a four speed cuda before....
The attachment tab is unavailble...now, so imagine....standard Cuda shifter with a T-shape RED handle on the left side of the shifter.....
-dc
SOUTHERNPLAINSMOPAARFEST.COM
2018 Jeep Trackhawk
1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997
1971 Barracuda, 414ci, 6bbl Fitech, 727
1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143443
08/29/16 10:46 PM
08/29/16 10:46 PM
Ontario, Canada
Stanton Online content
Don't question me!
Stanton  Online Content
Don't question me!
Ontario, Canada
Its a close-pattern shifter with a reverse lock-out feature to ensure no idiot puts it in reverse instead of 1st. The only real downside is a) the extra slot in the boot and b) if you ever have to "rock" the car out of a snowbank its gonna be tough!
I have one and swapped in a pistol grip handle!
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143627
08/30/16 02:56 AM
08/30/16 02:56 AM
I've installed two or three Super Competion + 3 shifters in one A body and I think two E bodys(back in the mid 1970s), the linkage rods from the shifter to the arms on the trannys rubbed agianst the dang tranny crossmembers is what I remember about themrunaway You may need to make(grind, cut) some clearnaces on yours so they don't rub scope thumbsThe stock Competion + shifters didn't have that problem work shruggy
the E body shifter rods are really long compared to all the other Mopar body style shifters due to the shifter mount on the rear of the tailshaft housing shruggy I bent the stock rods up pretty bad on my original Competion + shifter so I went with the S.C.+ 3, there rods have sleeves on them and they are a lot straighter to start with up
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: Cab_Burge] #2143804
08/30/16 12:37 PM
08/30/16 12:37 PM
Ormond Beach, FL
Ormond Beach, FL
Well, I'm going to give this a try. The Rods are beefier, and the lcok out handle will be something to deal with. I spoke to the owner who pulled this out of a 70 AAR Cuda. He said it worked like a champ, but the car was wrecked, so he got first dibbs on it. Any other thoughts are more than welcome....hoping to get my Cuda gear jammin' this winter.....
-dc
2018 Jeep Trackhawk
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: Stanton] #2143849
08/30/16 01:45 PM
08/30/16 01:45 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I know you live in Canada but I don't see him having to get that car out of a snowbank ????
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143850
08/30/16 01:45 PM
08/30/16 01:45 PM
Ormond Beach, FL
Ormond Beach, FL
Why can't I attach pics to this.....
-dc
2018 Jeep Trackhawk
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143859
08/30/16 01:55 PM
08/30/16 01:55 PM
U.S.S.A.
U.S.S.A.
Because you don't know how ?
if from your computer use the file manager button below the box you type your reply in
if on a smart phone I have no clue ...
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143911
08/30/16 02:50 PM
08/30/16 02:50 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
Others would have seen the humor in that statement. You, on the other hand, are always looking for something to pounce on.
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: Stanton] #2143915
08/30/16 02:53 PM
08/30/16 02:53 PM
U.S.S.A.
U.S.S.A.
Oh you mean like you do ?
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2143946
08/30/16 03:50 PM
08/30/16 03:50 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The reverse lockouts I am familiar with from back in the day were made by hurst and consisted of a sliding plate assembly that was sandwiched between the shifter and trans. It was designed to prevent catching the Neutral gate when power shifting between 1st and second. They sold a kit for factory type shifters and the super shifters came with them as I recall. They could be left in the blocked or unblocked position. I consider them mandatory for 4 spd cars that are driven hard.
the super shifters also normally come with a short stick. cruising through Hurst catalog would usually provide one with a suitable stick for the application. One normally could also adapt the stock handle with some effort
Reverse lockout kit pic
Super shifter with reverse lockout
beer
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: JohnRR] #2144661
08/31/16 04:34 PM
08/31/16 04:34 PM
Ormond Beach, FL
Ormond Beach, FL
Well I'm hosed because the files are too large anyways.
Thanks for the heads up, it's been a while since I posted on Moparts. The last post answered my question except his pic is a newer style lockout, mine is a flat red handle...easily(or so it appears)to be left in the up or down position.
Once I go through the trans, and gather the odds n ends to get this sucker fully converted....you all will hear back from me...thanks again, as always, Moparts rocks. -dc
-dc
2018 Jeep Trackhawk
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2144836
08/31/16 07:58 PM
08/31/16 07:58 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
There were two separate picture links in my post. the first is of a,
Reverse lockout kit, typically used with non equipped Hurst shifters and some factory units.
the second is a,
Super shifter with reverse lockout.
they may have changed some things over the years but that is what was available back in the 70's, 80's & 90's
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2144865
08/31/16 08:39 PM
08/31/16 08:39 PM
Ontario, Canada
Don't question me!
Don't question me!
Ontario, Canada
both photos are of the same thing.
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: Stanton] #2145108
09/01/16 01:03 AM
09/01/16 01:03 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
you are correct sir, HMM shruggy
This should be a pic of the super shifter that came equipped with the lockout
Super shifter with Flat t handle lockout
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: 71STROKERFISH] #2145536
09/01/16 05:35 PM
09/01/16 05:35 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I installed one of these shifters in late 70's, early 80’s in a Challenger. I used the factory rods which did require some minor massaging like Cab_Burge indicated. I remember having to add approximately .25"-.50" of rod / swivel adjustment by cutting more thread on the rod for proper alignment. In this application the shifter bolted on to the stock shifter plate location.
The other option (which I never tried) was to mount the shifter using the relocation bracket as seen in TJP's picture. This raised the shifter but allowed the use of the straight rods (i.e. Ramrod) which was designed more for racing. It may have slightly altered the shifter location from the factory opening in the hump as well??
I do recall having to slit my shifter boot. Funny how much heat came through that little slit too. As you can see, I was able to retain my center console. As I recall these were called Hurst Super Shifters.
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: cruzin] #2145802
09/01/16 11:55 PM
09/01/16 11:55 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe you are correct up
I'm digging the AWESOME audio equalizer hanging below the dash. definitely a back in the day pic, beer up popcorn
Re: 4-SPEED REVERSE LOCKOUT TRANS [Re: TJP] #2146400
09/02/16 08:56 PM
09/02/16 08:56 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
FWIW, I have a Super Shifter that I purchased new in the 70's that does not have the reverse lock out.
