Re: Grinding gears - distributor gears that is...Help !
[Re: indcontrols]
#2131036
08/12/16 12:47 PM
08/12/16 12:47 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I'm pretty sure the crane gear is not recommended for high volume oil pumps.
If that one wears, it will probably take out the gear on the cam with it.
[Re: fast68plymouth]
#2131083
08/12/16 01:52 PM
08/12/16 01:52 PM
Posts: 4,684 Wichita
GY3
Wichita
If that one wears, it will probably take out the gear on the cam with it. You are correct. The instructions with the Crane gear state that it is not to be used with a high volume pump.
[Re: GY3]
#2131163
08/12/16 03:07 PM
08/12/16 03:07 PM
BradH
If that one wears, it will probably take out the gear on the cam with it. You are correct. The instructions with the Crane gear state that it is not to be used with a high volume pump. I didn't think it is supposed to be run on a used cam, either.
[Re: indcontrols]
#2131263
08/12/16 05:00 PM
08/12/16 05:00 PM
Thumperdart
State of confusion
Don`t have part #`s but there`s a 3-piece torrington kit that goes under the gear and I`ve been running it for a couple of years..........
[Re: indcontrols]
#2131325
08/12/16 06:29 PM
08/12/16 06:29 PM
fast68plymouth
So. Burlington, Vt.
The bottom line is, when the two gears are in proper proximity to each other, they will last way way longer than 8 passes. There is a problem and it needs to be rectified, otherwise I don't think any type of gear will hold up.
When I ran a roller in my old 448 I just bought a bronze gear and pressed it onto my old oem shaft. Ran it for 3 seasons(a couple hundred passes, plus two dyno sessions), and it showed almost no wear on it when I pulled that motor apart.
That being said, I will say that over the last 8-10 years I have seen some roller cam cores that had some pretty sharp teeth on the gear. When they are like that, I put a chamfer on the edges of the teeth as a little insurance.
#2131714
08/13/16 01:41 AM
08/13/16 01:41 AM
BradH
That being said, I will say that over the last 8-10 years I have seen some roller cam cores that had some pretty sharp teeth on the gear. When they are like that, I put a chamfer on the edges of the teeth as a little insurance. Crap... now I guess I better pull the cam back outta the short block and check the bleepin' gear.
