Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2130891
08/12/16 07:20 AM
08/12/16 07:20 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I started with a used gear, now at 350 passes. Jessel with .010" endplay. Indymax pump. 5W30 synthetic with similar oil pressure. Is it set-up for a thrust washer below the gear? Maybe that's why the gear sets low?
Doug
Re: Grinding gears - distributor gears that is...Help ! [Re: dvw] #2130918
08/12/16 09:54 AM
08/12/16 09:54 AM
moparx Offline
moparx  Offline
doug, was that a used OEM gear or a used bronze gear ?
beer
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2130933
08/12/16 10:34 AM
08/12/16 10:34 AM
South Florida
indcontrols Offline OP
South Florida
I'm having the same thought about it having been set up for a thrust bearing since the wear pattern is high. I went ahead and ordered a crane gear.
Re: Grinding gears - distributor gears that is...Help ! [Re: moparx] #2130951
08/12/16 11:16 AM
08/12/16 11:16 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
beer
Used bronze gear.
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2131036
08/12/16 12:47 PM
08/12/16 12:47 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I'm pretty sure the crane gear is not recommended for high volume oil pumps.
If that one wears, it will probably take out the gear on the cam with it.
Re: Grinding gears - distributor gears that is...Help ! [Re: fast68plymouth] #2131083
08/12/16 01:52 PM
08/12/16 01:52 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
You are correct. The instructions with the Crane gear state that it is not to be used with a high volume pump.
'63 Dodge 330
11.19 @ 121 mph
Re: Grinding gears - distributor gears that is...Help ! [Re: GY3] #2131163
08/12/16 03:07 PM
08/12/16 03:07 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I didn't think it is supposed to be run on a used cam, either.
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2131224
08/12/16 04:05 PM
08/12/16 04:05 PM
South Florida
South Florida
Ok, well if it's not recommended for a high volume, it sure as hell won't hold up to the Kieth black pump...I think it is largely due to being too low - I hope. Anyone know where to get the thrust bearings?
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2131260
08/12/16 04:54 PM
08/12/16 04:54 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Go to bearing supply house and get some Torrington thrust washers.
Doug
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2131263
08/12/16 05:00 PM
08/12/16 05:00 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Don`t have part #`s but there`s a 3-piece torrington kit that goes under the gear and I`ve been running it for a couple of years..........
Re: Grinding gears - distributor gears that is...Help ! [Re: indcontrols] #2131325
08/12/16 06:29 PM
08/12/16 06:29 PM
So. Burlington, Vt.
So. Burlington, Vt.
The bottom line is, when the two gears are in proper proximity to each other, they will last way way longer than 8 passes.
There is a problem and it needs to be rectified, otherwise I don't think any type of gear will hold up.
When I ran a roller in my old 448 I just bought a bronze gear and pressed it onto my old oem shaft. Ran it for 3 seasons(a couple hundred passes, plus two dyno sessions), and it showed almost no wear on it when I pulled that motor apart.
That being said, I will say that over the last 8-10 years I have seen some roller cam cores that had some pretty sharp teeth on the gear.
When they are like that, I put a chamfer on the edges of the teeth as a little insurance.
Re: Grinding gears - distributor gears that is...Help ! [Re: fast68plymouth] #2131714
08/13/16 01:41 AM
08/13/16 01:41 AM
BradH Offline
BradH  Offline
Crap... now I guess I better pull the cam back outta the short block and check the bleepin' gear.
