line locks #2123201
08/02/16 08:06 AM
08/02/16 08:06 AM
michigan
richard h Offline OP
michigan
have a 69 dart. my propotionating valve has 4 lines coming out and going to all 4 brakes. so i put my line lock in after the master on the front brake line coming out,it is brand new from jeggs. you can hear the sylonoid actuating when you press the button but it will not lock the front brakes. i have never seen a prop valve like this with a line comming out for all four brakesshould i go after the prop valve and try to tee in?
Re: line locks [Re: richard h] #2123271
08/02/16 10:54 AM
08/02/16 10:54 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Is the solenoid mounted backwards? The solenoid only stops the flow one way.
How many lines go into the prop valve? If there are 4 out there should be two in.
Re: line locks [Re: richard h] #2123277
08/02/16 11:03 AM
08/02/16 11:03 AM
an8sec70cuda Offline
Just to clear something up in the way you worded it. You installed it on the line coming out of the rear of the master cylinder, correct? The front line of the master cylinder feeds the rear brakes.
So you mash the brake pedal, press the linelock button, release the pedal, and the car still moves forward?
CHIP
'06 GMC 2500HD LBZ Duramax
Re: line locks [Re: richard h] #2123285
08/02/16 11:14 AM
08/02/16 11:14 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This is very confusing, first tell us what modifications were made to your braking system because
A) a 69 dart did not come with a proportioning valve that has 4 lines coming out of it and
B) The DISTRIBUTION block that it has/had stock does not have a separate line for each rear brake ..
Re: line locks [Re: richard h] #2127471
08/07/16 10:40 PM
08/07/16 10:40 PM
pasadena,md
red 69 runner Offline
pasadena,md
I just got a moroso one from summit and the instructions show connecting the line for the front brakes to the unit and out of the unit you need a seperate tee fitting to connect the front brake lines to,the front brake lines do not connect to the same block as the back brakes,you have to plug up the hole that the front brake lines off the master cylendar connect to.
Re: line locks [Re: richard h] #2127482
08/07/16 10:53 PM
08/07/16 10:53 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
'69 RR ... cut the line out of the master for the front brakes, installed the line lock. Everything works fine.
Re: line locks [Re: richard h] #2127617
08/08/16 01:21 AM
08/08/16 01:21 AM
Pgh, PA
Bull1tt Offline
Bull1tt  Offline
Pgh, PA
I am not trying to be a smart a$$, but you need to apply pressure to the brake first, hold, and hit the button
Re: line locks [Re: richard h] #2127712
08/08/16 10:38 AM
08/08/16 10:38 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
The solenoid is a a one-way valve. You can hold the button then apply the brakes and the fluid will still flow to the brakes.
