Re: line locks
[Re: richard h]
#2123277
08/02/16 11:03 AM
08/02/16 11:03 AM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Just to clear something up in the way you worded it. You installed it on the line coming out of the rear of the master cylinder, correct? The front line of the master cylinder feeds the rear brakes.
So you mash the brake pedal, press the linelock button, release the pedal, and the car still moves forward?
Re: line locks
[Re: richard h]
#2123285
08/02/16 11:14 AM
08/02/16 11:14 AM
Posts: 75,062 U.S.S.A.
JohnRR
U.S.S.A.
have a 69 dart. my propotionating valve has 4 lines coming out and going to all 4 brakes. so i put my line lock in after the master on the front brake line coming out,it is brand new from jeggs. you can hear the sylonoid actuating when you press the button but it will not lock the front brakes. i have never seen a prop valve like this with a line comming out for all four brakesshould i go after the prop valve and try to tee in? This is very confusing, first tell us what modifications were made to your braking system because A) a 69 dart did not come with a proportioning valve that has 4 lines coming out of it and B) The DISTRIBUTION block that it has/had stock does not have a separate line for each rear brake ..
Re: line locks
[Re: richard h]
#2127617
08/08/16 01:21 AM
08/08/16 01:21 AM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
have a 69 dart. my propotionating valve has 4 lines coming out and going to all 4 brakes. so i put my line lock in after the master on the front brake line coming out,it is brand new from jeggs. you can hear the sylonoid actuating when you press the button but it will not lock the front brakes. i have never seen a prop valve like this with a line comming out for all four brakesshould i go after the prop valve and try to tee in? I am not trying to be a smart a$$, but you need to apply pressure to the brake first, hold, and hit the button
Re: line locks
[Re: richard h]
#2127712
08/08/16 10:38 AM
08/08/16 10:38 AM
Posts: 8,882 Ontario, Canada
Stanton
Don't question me!
Don't question me!
Ontario, Canada
but you need to apply pressure to the brake first, hold, and hit the button The solenoid is a a one-way valve. You can hold the button then apply the brakes and the fluid will still flow to the brakes.
