5.9 exhaust studs should come out right? #2107129
07/10/16 02:05 AM
07/10/16 02:05 AM
Andrewh Offline OP
Andrewh  Offline OP
just making sure I don't break anything.
The 2 center exhaust studs are in pretty good. but I should be able to double nut and back them out right?
nothing weird about them?
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107131
07/10/16 02:08 AM
07/10/16 02:08 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I assume you mean 5.9 Magnum, it should and they should not be wet either so no corrosion from coolant exposure.
Don't be the exception.
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107132
07/10/16 02:13 AM
07/10/16 02:13 AM
Andrewh Offline OP
Andrewh  Offline OP
sorry, yes 5.9 magnum.
trying to get the drivers exhaust off so I can pull the gear box.
with those 2 in, it won't clear to pull it out.
gave up for the night and will give it a go in the morning.
thanks
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107217
07/10/16 11:10 AM
07/10/16 11:10 AM
Spencer NY
killermopar Offline
killermopar  Offline
Spencer NY
I don't know how much room you have. I have in the past gotten a bigger nut and welded it on the end of the stud. It heats it for removal, and you can use the nut to spin it out.
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107239
07/10/16 11:57 AM
07/10/16 11:57 AM
Andrewh Offline OP
Andrewh  Offline OP
well I want to reuse them, so no welding anyway.
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107257
07/10/16 12:41 PM
07/10/16 12:41 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
They can get stuck from the heat. I wouldn't try to re-use them unless they come right out. Buy new bolts.
**Photobucket sucks**
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107274
07/10/16 01:18 PM
07/10/16 01:18 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We did the ones on the Durango when we replaced the manifold.I used my stud remover.Some good penetrating oil and they came right out.Used new ones as said as they are cheap.Rocky
Chrysler Firepower
Re: 5.9 exhaust studs should come out right? [Re: therocks] #2107307
07/10/16 02:31 PM
07/10/16 02:31 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Double nut them as you said and make sure you use a torch and heat the head where the studs go in, don't heat the studs.
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107321
07/10/16 02:51 PM
07/10/16 02:51 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
Can you remove the engine mount bolts and lift the engine slightly to gain access? Exhaust stud removal could have bad possibilities depending on many factors.
Never worked on this vehicle so it may not help.
Re: 5.9 exhaust studs should come out right? [Re: NANKET] #2107341
07/10/16 03:22 PM
07/10/16 03:22 PM
Alberta
440_Offroader Offline
Alberta
If you heat the studs, let them cool before you try to take them out. If they are still hot, even warm, the treads will pile up. Then you'll be hating life. The expansion and contraction of the stud will loosen it up.
Re: 5.9 exhaust studs should come out right? [Re: 440_Offroader] #2107345
07/10/16 03:27 PM
07/10/16 03:27 PM
Alberta
Alberta
When I say heat the stud, get it glowing red hot...
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107346
07/10/16 03:27 PM
07/10/16 03:27 PM
Its a TRAP!
DARTH V8Я Offline
Oh No!! I just had a moron attack!
DARTH V8Я  Offline
Its a TRAP!
I usually heat the stud, then immediately hit it with Water Displacement 40th try. Repeat a few times & the studs will come right out (double nutted).
When it takes more than a sweet mullet to prove you rule at the trailer park..
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107369
07/10/16 04:14 PM
07/10/16 04:14 PM
Andrewh Offline OP
Andrewh  Offline OP
I don't really have any way to heat them up that hot. no torch.
Plus the exhaust is still hanging off them. That would suck up a lot of the heat.
I had thought about unbolting the motor mount, but I remember how much of a pain it was getting them in, I am afraid to do that.
I just wish I could remember if we stabbed the motor in with the manfolds on or if I put them on after. if I did it after then they had to be out and I coated them with anti-seeze(sp).
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107601
07/10/16 11:55 PM
07/10/16 11:55 PM
Andrewh Offline OP
Andrewh  Offline OP
never got them out.
loosened the motor mount and I could clear the ps box.
then I got the ps box out.
I put the exhaust back in while the ps box was loose.
Re: 5.9 exhaust studs should come out right? [Re: Andrewh] #2107956
07/11/16 03:50 PM
07/11/16 03:50 PM
northwest USA
N
NANKET Online work
NANKET  Online Work
N
northwest USA
A happy ending
