Re: 5.9 exhaust studs should come out right?
[Re: Andrewh]
#2107131
07/10/16 02:08 AM
07/10/16 02:08 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
I assume you mean 5.9 Magnum, it should and they should not be wet either so no corrosion from coolant exposure.
[Re: Andrewh]
#2107257
07/10/16 12:41 PM
07/10/16 12:41 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
They can get stuck from the heat. I wouldn't try to re-use them unless they come right out. Buy new bolts.
**Photobucket sucks**
[Re: Andrewh]
#2107274
07/10/16 01:18 PM
07/10/16 01:18 PM
Posts: 21,074 Niles , Ohio
therocks
Niles , Ohio
We did the ones on the Durango when we replaced the manifold.I used my stud remover.Some good penetrating oil and they came right out.Used new ones as said as they are cheap.Rocky
Chrysler Firepower
[Re: therocks]
#2107307
07/10/16 02:31 PM
07/10/16 02:31 PM
Posts: 2,520 God's Country Maryland
GODSCOUNTRY340
Double nut them as you said and make sure you use a torch and heat the head where the studs go in, don't heat the studs.
[Re: 440_Offroader]
#2107345
07/10/16 03:27 PM
07/10/16 03:27 PM
Posts: 257 Alberta
440_Offroader
Alberta
When I say heat the stud, get it glowing red hot...
[Re: Andrewh]
#2107346
07/10/16 03:27 PM
07/10/16 03:27 PM
Posts: 2,154 Its a TRAP!
DARTH V8Я
Oh No!! I just had a moron attack!
Its a TRAP!
I usually heat the stud, then immediately hit it with Water Displacement 40th try. Repeat a few times & the studs will come right out (double nutted).
When it takes more than a sweet mullet to prove you rule at the trailer park..
