Still not enough caster even with Moog offsets installed. #2034423
03/19/16 12:55 PM
03/19/16 12:55 PM
eastern, pa.
cudabitten Offline OP
eastern, pa.
I just got my front end aligned after my complete rebuild. I turned out ok but the alignment guy could only get about a zero degree caster. I installed the Moog offsets when I rebuilt everything. I guess I should be glad that I installed them, but was hoping to have a better alignment outcome. As far as I can remember, he explained that he used the camber to gain as much caster as he could. I think the car is in spec because the program had all the numbers turn from red to green as he made adjustments.
He said the best fix would be adjustable struts, so maybe I will install those at some point.
He also found that my rear axle housing is pointing outward on one side by about 1/8 inch, and I also have an inner tie rod end with reversed threads, I guess someone installed two inners or two outers on the one side, unfortunately the sleeve is now cross threaded. I may fix that at the same time I install the adjustable struts, and then get it re-aligned.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034434
03/19/16 01:18 PM
03/19/16 01:18 PM
Andrewh Offline
Andrewh  Offline
you might check the cost vs the firm feel upper control arms instead.
I went that route instead of the moog bushings.
also if you are going to change out the sleeve, you might consider ordering the 74 newport sleeves and tie rod ends. as it gives you the larger diameter ones and they are cheaper than the b-body set.
as for the rear, someone makes shims to move it one way or the other as I recall. they slide in so you don't have to take it apart.
Re: Still not enough caster even with Moog offsets installed. [Re: Andrewh] #2034474
03/19/16 02:09 PM
03/19/16 02:09 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I had the same issue on my '68 Barracuda even with the Firm Fell upper control arms. It wasn't until I installed the Hotchkis adjustable strut rods that I was able to get the caster above 1/2 degree. Having a bit of a rake from front to rear didn't help matters.
I took the car in for an alignment and the caster is now set at 5* positive caster. It tracks down the road and handles so much better than before, and it doesn't pull on crowned roads. It completed the package of some of the best components I've put in the front end including a firm Feel power steering box, stiffer 1" T bars, sway bar and Koni's.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034480
03/19/16 02:10 PM
03/19/16 02:10 PM
CA
crackedback Offline
crackedback  Offline
CA
The computer numbers Hunter and other alignment racks, red/green are not very good on our older mopars. Most of those "specs" for go/no go don't provide enough caster.
Crazy question, were your offset bushings installed with the correct orientation?
Re: Still not enough caster even with Moog offsets installed. [Re: crackedback] #2034490
03/19/16 02:37 PM
03/19/16 02:37 PM
Post what numbers he DID come up with. as you know you need a RH and a LH thread tie rod end (1 of each) on each (pass & dr) side. LH threads have a distinctive angled twist that you cant mistake as compared to RH (regular) threads which are straight to the naked eye.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034492
03/19/16 02:43 PM
03/19/16 02:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Are you running poly strut rod bushings?
Could you take pictures of the front and rear cam eccentrics for each side. That will tell/confirm if there is any adjustment left.
Like Robert said, the actual numbers he got could clue in to what is happening.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034498
03/19/16 02:54 PM
03/19/16 02:54 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If you aren't running poly bushings did anyone verify the frame is straight?
With caster off and the rear crooked one wonders.
Don't be the exception.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034596
03/19/16 06:19 PM
03/19/16 06:19 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
... I installed the Moog offsets when I rebuilt everything.
But were they installed correctly, so NOT according to the MOOG manual?
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034690
03/19/16 09:17 PM
03/19/16 09:17 PM
Minn
SportF Offline
SportF  Offline
Minn
I have put in a fair number of the off set bushings and they really never gave anything for the effort. I won't even try it again.
It looks like they should increase castor by a degree or better, but just not so in my experience. I might add 1 degree of positive castor seems to work, I just would like more.
Best of luck on your effort.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2034706
03/19/16 09:40 PM
03/19/16 09:40 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
These cars, like all others, had a range of acceptable build tolerances. The ideal is in the middle of that range but some cars end up at one end of the range or another.
Putting it another way: Say the upper control arm mounts are to be welded into the frame between 11.0 to 11.125 inches from a specific datum point. The 11.0 position technically puts the upper ball joint further forward, making positive caster less likely than the 11.125 number. I have the Moog offset bushings in my 70 Charger along with urethane strut rod bushings. My alignment guy was able to get 4.0 degrees of caster on each side with stock control arms. Granted, I am one of the lucky ones but cases like mine do exist.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035060
03/20/16 02:24 PM
03/20/16 02:24 PM
NC
1970A66 Offline
1970A66  Offline
NC
Do you trust your alignment guy?
Reason I ask is, a couple years ago I installed Firm Feel upper arms. Took the car to an alignment shop that's been around for ever, family run thing. He couldn't get any more than zero caster on one side and 2 on the other. Told me the FF arms aren't right or the car must be bent. I called FF and talked to dick, he said they jigged up the tubes and welded them and this would be the first time if they weren't right.
I asked around in my car club who they all use for alignments, got one name consistently. Took the car there with a bunch of spare parts if needed.
The guy called me later that day said it is good to go. It aligned right up with 5 degrees caster with the FF arms.
He had no idea why the guy down the street couldn't make it happen..............
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035093
03/20/16 02:59 PM
03/20/16 02:59 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 65 I couldnt get a lot of caster with them.It did improve and I got it close to 1 degree.That was max.I did it myself at work so I knew it was right.Just depends on the car I guess.Rocky
Chrysler Firepower
Re: Still not enough caster even with Moog offsets installed. [Re: therocks] #2035176
03/20/16 05:43 PM
03/20/16 05:43 PM
eastern, pa.
eastern, pa.
Lots of good feedback here, thanks guys...
Here is the report.
Also, here are a few pics, the rear cams are the same as the fronts.
I used all Moog Rubber bushings including the struts etc. I remember following the directions here for the offset installation which was exactly opposite of the Moog instructions I think. I guess I could double check that if I remove the wheel.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035224
03/20/16 07:17 PM
03/20/16 07:17 PM
The Netherlands
The Netherlands
What do you mean by this?
The rear cams should be oriented opposite, adjusted inward to the car's center. Is that the case?
Re: Still not enough caster even with Moog offsets installed. [Re: BigBlockMopar] #2035319
03/20/16 09:28 PM
03/20/16 09:28 PM
eastern, pa.
eastern, pa.
Here are the back side pics. Driver tough to see.
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035342
03/20/16 10:06 PM
03/20/16 10:06 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The front cams are close to the max positive caster and camber position. The rear cam shown is close to the max positive camber and max negative caster position. I can't read the numbers on your slip. If the camber is around zero either the lower control arm bushings are shot, the strut rods/mounts are pushed back, or the rails are tipped in, unless the car has a 4-5 degree rake. Moving the rear cam in would increase caster and decrease camber.
Doug
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035370
03/20/16 10:28 PM
03/20/16 10:28 PM
eastern, pa.
eastern, pa.
Here is an attempt to type the results.
Left Front Right Front
Actual Actual
-0.02' Camber 0.01'
-0.105' Caster 0.055'
0.07" Toe 0.07"
Cross Camber -0.02'
Cross Caster -0.16'
Left Rear Right Rear
-0.06 Camber 0.02'
0.00 Toe -0.18"
Total Toe -0.18"
Thrust Angle 0.11'
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035507
03/21/16 01:29 AM
03/21/16 01:29 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
My understanding of those Moog bushings is that if you install them according to the Moog instructions they won't help your caster. I believe the reason is that caster was not the problem they were designed to solve. They are for gaining +camber.
Someone I'm sure will be forthcoming with the correct procedure to make them give you a positive caster gain.
Kevin
Re: Still not enough caster even with Moog offsets installed. [Re: cudabitten] #2035562
03/21/16 07:33 AM
03/21/16 07:33 AM
ohio
ruderunner Online content
ruderunner  Online Content
ohio
The bushings shouldn't be installed opposite of the instructions, that won't gain a caster improvement, just gets a different camber range.
The front bushing in the arm needs to have the thin side towards the engine and the rear bushing needs to have the fat side towards the engine.
My guess is you have the fat side towards the engine in all positions.
Angry white pureblood male
Re: Still not enough caster even with Moog offsets installed. [Re: Twostick] #2035570
03/21/16 08:36 AM
03/21/16 08:36 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Kevin
The offset bushings function to allow the front of the control arm to have more range of adjustment outward. This gains camber. This also allows for the rear to be adjusted inward to remove that gained camber gaining caster. Cut a 45 degree triangle piece of cardboard with an arrow pointing forward. The 90 degree corner represents the upper ball joint, the corner at the front of the arrow the front cam, the other corner the rear cam. Lay it on a piece of paper and mark all 3 corners where the cardboard sits. Now move the front corner out and the rear in. Note where this places the ball joint. This move changes caster w/o changing camber. Moving both corners equally changes camber w/o affecting caster. Moving only one corner changes both camber and caster.
Hope this helps. By this we can see from the chart and the alignment sheet that the alignment tech is correct, it's maxed out on adjustment. Sometimes there may still be adjustment in one side. However caster needs to be equal so you have to match to the side that has the maxed out adjustment. I'd like to see the other rear cam position.
Doug
Hope this helps.
