Re: Still not enough caster even with Moog offsets installed.
[Re: Andrewh]
#2034474
03/19/16 02:09 PM
03/19/16 02:09 PM
Posts: 3,285 West Coast, USA
jbc426
West Coast, USA
I had the same issue on my '68 Barracuda even with the Firm Fell upper control arms. It wasn't until I installed the Hotchkis adjustable strut rods that I was able to get the caster above 1/2 degree. Having a bit of a rake from front to rear didn't help matters.
I took the car in for an alignment and the caster is now set at 5* positive caster. It tracks down the road and handles so much better than before, and it doesn't pull on crowned roads. It completed the package of some of the best components I've put in the front end including a firm Feel power steering box, stiffer 1" T bars, sway bar and Koni's.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: crackedback]
#2034490
03/19/16 02:37 PM
03/19/16 02:37 PM
RapidRobert
Post what numbers he DID come up with. as you know you need a RH and a LH thread tie rod end (1 of each) on each (pass & dr) side. LH threads have a distinctive angled twist that you cant mistake as compared to RH (regular) threads which are straight to the naked eye.
[Re: cudabitten]
#2034492
03/19/16 02:43 PM
03/19/16 02:43 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I just got my front end aligned after my complete rebuild. I turned out ok but the alignment guy could only get about a zero degree caster. I installed the Moog offsets when I rebuilt everything. I guess I should be glad that I installed them, but was hoping to have a better alignment outcome. As far as I can remember, he explained that he used the camber to gain as much caster as he could. I think the car is in spec because the program had all the numbers turn from red to green as he made adjustments. He said the best fix would be adjustable struts, so maybe I will install those at some point. He also found that my rear axle housing is pointing outward on one side by about 1/8 inch, and I also have an inner tie rod end with reversed threads, I guess someone installed two inners or two outers on the one side, unfortunately the sleeve is now cross threaded. I may fix that at the same time I install the adjustable struts, and then get it re-aligned. Are you running poly strut rod bushings? Could you take pictures of the front and rear cam eccentrics for each side. That will tell/confirm if there is any adjustment left. Like Robert said, the actual numbers he got could clue in to what is happening.
[Re: cudabitten]
#2034498
03/19/16 02:54 PM
03/19/16 02:54 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
If you aren't running poly bushings did anyone verify the frame is straight?
With caster off and the rear crooked one wonders.
[Re: cudabitten]
#2034596
03/19/16 06:19 PM
03/19/16 06:19 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
... I installed the Moog offsets when I rebuilt everything. But were they installed correctly, so NOT according to the MOOG manual?
[Re: cudabitten]
#2035093
03/20/16 02:59 PM
03/20/16 02:59 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
My 65 I couldnt get a lot of caster with them.It did improve and I got it close to 1 degree.That was max.I did it myself at work so I knew it was right.Just depends on the car I guess.Rocky
Chrysler Firepower
[Re: therocks]
#2035176
03/20/16 05:43 PM
03/20/16 05:43 PM
Posts: 958 eastern, pa.
cudabitten
eastern, pa.
Lots of good feedback here, thanks guys... Here is the report. Also, here are a few pics, the rear cams are the same as the fronts. I used all Moog Rubber bushings including the struts etc. I remember following the directions here for the offset installation which was exactly opposite of the Moog instructions I think. I guess I could double check that if I remove the wheel.
[Re: cudabitten]
#2035224
03/20/16 07:17 PM
03/20/16 07:17 PM
BigBlockMopar
The Netherlands
the rear cams are the same as the fronts What do you mean by this? The rear cams should be oriented opposite, adjusted inward to the car's center. Is that the case?
[Re: cudabitten]
#2035342
03/20/16 10:06 PM
03/20/16 10:06 PM
Posts: 9,848 MI, usa
dvw
MI, usa
The front cams are close to the max positive caster and camber position. The rear cam shown is close to the max positive camber and max negative caster position. I can't read the numbers on your slip. If the camber is around zero either the lower control arm bushings are shot, the strut rods/mounts are pushed back, or the rails are tipped in, unless the car has a 4-5 degree rake. Moving the rear cam in would increase caster and decrease camber. Doug
[Re: cudabitten]
#2035370
03/20/16 10:28 PM
03/20/16 10:28 PM
cudabitten
eastern, pa.
Here is an attempt to type the results.
Left Front Right Front Actual Actual -0.02' Camber 0.01' -0.105' Caster 0.055' 0.07" Toe 0.07"
Cross Camber -0.02' Cross Caster -0.16'
Left Rear Right Rear -0.06 Camber 0.02' 0.00 Toe -0.18"
Total Toe -0.18" Thrust Angle 0.11'
[Re: cudabitten]
#2035562
03/21/16 07:33 AM
03/21/16 07:33 AM
Posts: 5,883 ohio
ruderunner
ohio
The bushings shouldn't be installed opposite of the instructions, that won't gain a caster improvement, just gets a different camber range.
The front bushing in the arm needs to have the thin side towards the engine and the rear bushing needs to have the fat side towards the engine.
My guess is you have the fat side towards the engine in all positions.
Angry white pureblood male
[Re: Twostick]
#2035570
03/21/16 08:36 AM
03/21/16 08:36 AM
dvw
MI, usa
My understanding of those Moog bushings is that if you install them according to the Moog instructions they won't help your caster. I believe the reason is that caster was not the problem they were designed to solve. They are for gaining +camber.
Someone I'm sure will be forthcoming with the correct procedure to make them give you a positive caster gain.
Kevin The offset bushings function to allow the front of the control arm to have more range of adjustment outward. This gains camber. This also allows for the rear to be adjusted inward to remove that gained camber gaining caster. Cut a 45 degree triangle piece of cardboard with an arrow pointing forward. The 90 degree corner represents the upper ball joint, the corner at the front of the arrow the front cam, the other corner the rear cam. Lay it on a piece of paper and mark all 3 corners where the cardboard sits. Now move the front corner out and the rear in. Note where this places the ball joint. This move changes caster w/o changing camber. Moving both corners equally changes camber w/o affecting caster. Moving only one corner changes both camber and caster. Hope this helps. By this we can see from the chart and the alignment sheet that the alignment tech is correct, it's maxed out on adjustment. Sometimes there may still be adjustment in one side. However caster needs to be equal so you have to match to the side that has the maxed out adjustment. I'd like to see the other rear cam position. Doug Hope this helps.
