48' W7's on a 59' R block? #1989396
01/12/16 06:26 PM
01/12/16 06:26 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Hello,
I was curious if anyone on this board has done this with good results? I know this can be done and I've read SDSS website about doing this, but is it worth it? I have a fully ported set of w5's ready to go but I've stumbled on these w7's and there taunting me! Lol
The heads are middle generation Chapman Craftsmen truck heads. 10 bolt. 598 intake etc. if I do go this route I'd like to have someone hand port these heads to get best power from them.
These will be on a full drag effort build. No street miles.
I know with having someone notch the intake runners and proper offset of the rockers they will work. But is it going to worth switching from my w5's? What else do I need to know about switching these heads over?
Custom pistons are required, I was planning on doing that for the w5's so nbd. I know these heads oil through the pushrods. What lifters and pushrods would I run? Would I have to install copper tubes in the oil lifter galleys? Is that the easiest option when running a big roller like I have?
If anyone could walk me through the steps with this I'd really appreciate it. I'm not really familiar with the W 7/8/9 stuff.
Also I've attached a couple photos. One being of my heads. What rockers style does this head run and can I even get a set? They will be custom I'm sure with requiring so much offset or does someone have a used set sitting around?
I thought I was set on the w5's but I can't stop thinking about these w7's sitting in our shop lol.
Thanks for all your help and patience, Mark
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989421
01/12/16 07:29 PM
01/12/16 07:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I wouldnt waste the time or money on that.. put
the W-5s on it... find a 48* block for a max effort
engine
EDIT
I might even have a set of TD rockers for the W-7s
wave
Re: 48' W7's on a 59' R block? [Re: MR_P_BODY] #1989440
01/12/16 08:06 PM
01/12/16 08:06 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
That's what I've been thinking too is finding a 48' block. But as we all know that's a problem lol. I'd be interested in those rockers if you do have them and want to sell?
Thanks, Mark
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989443
01/12/16 08:12 PM
01/12/16 08:12 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
One name comes to mine BRETT MILLER.
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989447
01/12/16 08:16 PM
01/12/16 08:16 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Thanks, Mark
I'll have to look.. I know at one time I did have
a set.. not sure if I sold them or not
wave
Re: 48' W7's on a 59' R block? [Re: MR_P_BODY] #1989449
01/12/16 08:19 PM
01/12/16 08:19 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Sounds good. Thanks!
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989452
01/12/16 08:20 PM
01/12/16 08:20 PM
People's Republic of Mass.
Belvedere2 Offline
Belvedere2  Offline
Wish I had those W-7s on my 48* short block. I never stumble over anything. Lol.
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989454
01/12/16 08:22 PM
01/12/16 08:22 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
I'm thinking run the w5's, and start to accumulate parts and knowledge for a nice w7 motor in the future. Do the w7 motor right the first timeπŸ‘πŸ»
Re: 48' W7's on a 59' R block? [Re: Belvedere2] #1989456
01/12/16 08:24 PM
01/12/16 08:24 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
I USUALLY don't either lol. I'm the guy who always misses a deal by a day.πŸ˜…
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989479
01/12/16 09:05 PM
01/12/16 09:05 PM
Belvedere2 Offline
Belvedere2  Offline
Me too. If you decide to unload them keep me in mind. I have a 380" shortblock waiting.
Re: 48' W7's on a 59' R block? [Re: Belvedere2] #1989505
01/12/16 10:03 PM
01/12/16 10:03 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I do but it usually results in me falling in a pile of $hit. biggrin
Re: 48' W7's on a 59' R block? [Re: justinp61] #1989545
01/12/16 10:58 PM
01/12/16 10:58 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Check the valve angle on those. There are a lot of variations on W7's. Also check how much the pads have been milled, who knows what setup was on there.
Re: 48' W7's on a 59' R block? [Re: Hot 340] #1989560
01/12/16 11:05 PM
01/12/16 11:05 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Will do!πŸ‘πŸ»
Re: 48' W7's on a 59' R block? [Re: Belvedere2] #1989564
01/12/16 11:06 PM
01/12/16 11:06 PM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
I will do that sir!
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989592
01/12/16 11:50 PM
01/12/16 11:50 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Is that bore under 4 inch looks tiny
Re: 48' W7's on a 59' R block? [Re: WHITEDART] #1989618
01/13/16 12:15 AM
01/13/16 12:15 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Yes, it's 3.9 and change I can't remember exactly. Pretty crazy it's sat untouched this many years.
Re: 48' W7's on a 59' R block? [Re: MGC340] #1989637
01/13/16 12:41 AM
01/13/16 12:41 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Siamese block??
Re: 48' W7's on a 59' R block? [Re: SpareParts] #1989646
01/13/16 12:51 AM
01/13/16 12:51 AM
oregon
greendart408 Offline
oregon
I had a twin to that block that I ran my w5s on. No oil holes to the deck from cam, a factory oil hole drilled to the water under the factory oil filter hole, not enough crank counter weight machining, so the crank won't even drop in the block and a slew of other stuff, IF it is truly a twin to my block lol!.
Re: 48' W7's on a 59' R block? [Re: SpareParts] #1989681
01/13/16 01:39 AM
01/13/16 01:39 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Originally Posted By SpareParts
Siamese block??
Non Siamese block. It's a early R block not R3
Re: 48' W7's on a 59' R block? [Re: greendart408] #1989682
01/13/16 01:42 AM
01/13/16 01:42 AM
Sioux Falls, SD
MGC340 Offline OP
MGC340  Offline OP
Sioux Falls, SD
Was your block a R3 block or R block? Thanks
