Re: 48' W7's on a 59' R block?
[Re: MGC340]
#1989421
01/12/16 07:29 PM
01/12/16 07:29 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I wouldnt waste the time or money on that.. put the W-5s on it... find a 48* block for a max effort engine EDIT I might even have a set of TD rockers for the W-7s
[Re: MGC340]
#1989443
01/12/16 08:12 PM
01/12/16 08:12 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
One name comes to mine BRETT MILLER.
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: MGC340]
#1989447
01/12/16 08:16 PM
01/12/16 08:16 PM
MR_P_BODY
That's what I've been thinking too is finding a 48' block. But as we all know that's a problem lol. I'd be interested in those rockers if you do have them and want to sell?
Thanks, Mark I'll have to look.. I know at one time I did have a set.. not sure if I sold them or not
[Re: Belvedere2]
#1989456
01/12/16 08:24 PM
01/12/16 08:24 PM
Posts: 127 Sioux Falls, SD
MGC340
Sioux Falls, SD
Wish I had those W-7s on my 48* short block. I never stumble over anything. Lol. I USUALLY don't either lol. I'm the guy who always misses a deal by a day.π
[Re: MGC340]
#1989479
01/12/16 09:05 PM
01/12/16 09:05 PM
Posts: 207 People's Republic of Mass.
Belvedere2
Me too. If you decide to unload them keep me in mind. I have a 380" shortblock waiting.
[Re: Hot 340]
#1989560
01/12/16 11:05 PM
01/12/16 11:05 PM
MGC340
Sioux Falls, SD
Check the valve angle on those. There are a lot of variations on W7's. Also check how much the pads have been milled, who knows what setup was on there. Will do!ππ»
[Re: Belvedere2]
#1989564
01/12/16 11:06 PM
01/12/16 11:06 PM
MGC340
Sioux Falls, SD
Me too. If you decide to unload them keep me in mind. I have a 380" shortblock waiting. I will do that sir!
[Re: MGC340]
#1989592
01/12/16 11:50 PM
01/12/16 11:50 PM
WHITEDART
bean town ....Ca
Is that bore under 4 inch looks tiny
[Re: WHITEDART]
#1989618
01/13/16 12:15 AM
01/13/16 12:15 AM
MGC340
Sioux Falls, SD
Is that bore under 4 inch looks tiny Yes, it's 3.9 and change I can't remember exactly. Pretty crazy it's sat untouched this many years.
[Re: greendart408]
#1989682
01/13/16 01:42 AM
01/13/16 01:42 AM
MGC340
Sioux Falls, SD
I had a twin to that block that I ran my w5s on. No oil holes to the deck from cam, a factory oil hole drilled to the water under the factory oil filter hole, not enough crank counter weight machining, so the crank won't even drop in the block and a slew of other stuff, IF it is truly a twin to my block lol!. Was your block a R3 block or R block? Thanks
