Re: bb to pg with chevy case
[Re: Chris Vanover]
#1976134
12/25/15 02:51 PM
12/25/15 02:51 PM
Posts: 19,384 Las Vegas
Al_Alguire
Las Vegas
We have an ATI Midplate adapter on our dragster with a Chevy Bell PG. They can be ordered to mount he starter on either side. Can get you a pic but wont see much as it is in the car
[Re: Chris Vanover]
#1976177
12/25/15 03:47 PM
12/25/15 03:47 PM
Posts: 20,199 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I'm kinda missing what you are looking for but here's a powerglide to MOPAR block bell housing.
[Re: Chris Vanover]
#1976259
12/25/15 06:09 PM
12/25/15 06:09 PM
Posts: 20,199 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Yep keep it simple. I cut all the noses off my starters so Matt and I can use them with 727's 904's, big block Ultrabells, and smallblock Ultrabells (powerglides). Every starter fits every application.
[Re: Chris Vanover]
#1976430
12/26/15 02:05 AM
12/26/15 02:05 AM
Posts: 422 montana
BANDIT
montana
I have the set-up you are describing on my Avenger. Starter is a Powermaster #9513 and mounted right below pan level. Starter bolts to midplate, I think it is an ATI mid plate because flexplate and spacer are but not 100% sure on that. I may still have the pictures I sent to engine builder if still on my home computer. Jim
64 Dodge Coronet 440. In progress 1998. Dodge Avenger. 8.35@165. 4400 DA 250” Neil and Parks Slip Joint. 7.36@183. 4600 DA 242" Mullis Dragster. 6.90@ 200mph
