bb to pg with chevy case #1975764
12/24/15 05:29 PM
12/24/15 05:29 PM
Pound, Va
Chris Vanover Offline OP
Pound, Va
Any one have any pics of this set up? Mainly curious as to what you have done to get the starter on it? any way to move the starter to the right side tucked down low? this is going in a dragster and id like to be able to keep the chevy bell housing if all possible and with out having to cut on it. i have the bbm bell housing if i must go that route.
Thanks for any help
Chris
Re: bb to pg with chevy case [Re: Chris Vanover] #1975888
12/24/15 10:49 PM
12/24/15 10:49 PM
illinois
E
evenflow Offline
evenflow  Offline
E
illinois
I have jw pg ultra bell in my dragster starter on right side upside down but it bolts to midplate
Re: bb to pg with chevy case [Re: Chris Vanover] #1975911
12/24/15 11:21 PM
12/24/15 11:21 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
Several companies offer adapter kits, here is a link to ATI: http://www.atiracing.com/products/adapterk/akit.htm
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: bb to pg with chevy case [Re: Chris Vanover] #1975944
12/25/15 12:52 AM
12/25/15 12:52 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
I've got a PG case and Ultrabell to match to my 500" rb motor. Starter motor is at the usual lower rear of block driver's side. What side are you identifying as the 'right' side? You need the midplate to accommodate with a cut-out for the starter nose and correctly located holes for attachment. You'll also need an approximately ~1/2" thick spacer to set the starter pinion gear to flexplate distance. The hard part for me was waiting for the Mopar to BBC Ultrabell delivery. HTH
Re: bb to pg with chevy case [Re: Chris Vanover] #1976025
12/25/15 09:16 AM
12/25/15 09:16 AM
HR3128 Offline
HR3128  Offline
http://www.coanracing.com/Catalog.asp?ProductDetail=1114
I used this plate on a dragster. Only problem was that the post for the starter cable was close to the oil pan. It did not touch but was closer than I liked. Easy to bang a little clearance on the pan.
Re: bb to pg with chevy case [Re: Chris Vanover] #1976134
12/25/15 02:51 PM
12/25/15 02:51 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have an ATI Midplate adapter on our dragster with a Chevy Bell PG. They can be ordered to mount he starter on either side. Can get you a pic but wont see much as it is in the car
Re: bb to pg with chevy case [Re: Chris Vanover] #1976177
12/25/15 03:47 PM
12/25/15 03:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'm kinda missing what you are looking for but here's a powerglide to MOPAR block bell housing.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: bb to pg with chevy case [Re: Chris Vanover] #1976220
12/25/15 05:00 PM
12/25/15 05:00 PM
Pound, Va
Pound, Va
I have the mid plate/ adapter plate and all that stuff. I guess what i really need is a pattern to cut/ drill the holes on the lower passenger side of the motor. anyone have one of them?
i have a jw to pg adapter and an ati case with the bbm housing already. just wanting to be able to stay with a chevy bell housing because all of our spares are that way and if needed i can find a spare trans at the track alot easier for the chevy stuff.
thanks for your replys.
Re: bb to pg with chevy case [Re: Chris Vanover] #1976259
12/25/15 06:09 PM
12/25/15 06:09 PM
PA.
"Little"John
"Little"John
PA.
Yep keep it simple. I cut all the noses off my starters so Matt and I can use them with 727's 904's, big block Ultrabells, and smallblock Ultrabells (powerglides). Every starter fits every application.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: bb to pg with chevy case [Re: Chris Vanover] #1976430
12/26/15 02:05 AM
12/26/15 02:05 AM
montana
BANDIT Offline
BANDIT  Offline
montana
I have the set-up you are describing on my Avenger. Starter is a Powermaster #9513 and mounted right below pan level. Starter bolts to midplate, I think it is an ATI mid plate because flexplate and spacer are but not 100% sure on that. I may still have the pictures I sent to engine builder if still on my home computer. Jim
64 Dodge Coronet 440. In progress
1998. Dodge Avenger. 8.35@165. 4400 DA
250” Neil and Parks Slip Joint. 7.36@183.
4600 DA
242" Mullis Dragster. 6.90@ 200mph
