Page 3 of 5 1 2 3 4 5
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1963866
12/05/15 06:01 PM
12/05/15 06:01 PM
oregon
greendart408 Offline
oregon
Are those flow #s from your bench or Hughes?
Re: SB Victor heads shipped...well, at least mine! [Re: greendart408] #1963873
12/05/15 06:08 PM
12/05/15 06:08 PM
CJD AUTOMOTIVE Offline OP
Hughes, but confirmed by Rick Roberts at Edelbrock. He's the production engineer on this head. That was the earlier version. Said the production heads #'s are a little better. I tend to believe him. Don't forget these are raised port (.750) , offset intake, and the valve laid down 2 degrees. I'll have them on the bench soon enough and we will all know.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
www.CJDAUTOMOTIVE.com
904-400-1802
"I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1963921
12/05/15 07:15 PM
12/05/15 07:15 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
I have had the CNC E-head in my hands.
If they go 330cfm on the bench I use I would fall over.
They have made lots of mistakes on this head that will need fixed
Make sure you take good picture of the oil drain back they put right in the intake bowl.
I will get a bare head and see what I can do with it.
And for around $2800.00 you could have set of w9s that will kill this head for power.
$1000 castings from Indy
$1250 CNC
$300 valve job
$100 surface
$150 blend CNC work and valve job
Don't take me the wrong way I am happy to see this head they have just make some bad calls on this head.
It is a nice casting and should hold lots of power on boost.
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1963932
12/05/15 07:28 PM
12/05/15 07:28 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Can't compare runner volume without figureing out the length of the runner, clearly the eddy is longer than normal. Also can't the W9 and indy for that matter be used with existing pistons? The eddy has different valve angles/locations meaning different pistons for sure, not that it is a bad thing if they flow more and make more HP just more $$$.
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1963988
12/05/15 08:47 PM
12/05/15 08:47 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
W7-9 are kind of a custom piston also, the indy is the only one being mentioned here that is still stock valve angle
Re: SB Victor heads shipped...well, at least mine! [Re: HotRodDave] #1963992
12/05/15 08:56 PM
12/05/15 08:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Is this Victor head a 48* or 59* head... if its a
48* I dont see why you cant compare it to the W-9..
I got my W-9 pistons from CP.. they were VERY NICE
and lite
wave
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1964184
12/06/15 02:59 AM
12/06/15 02:59 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
I have seen them also, have a hard time seeing those flow numbers out of a small port.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: SB Victor heads shipped...well, at least mine! [Re: 1967dartgt] #1964345
12/06/15 01:49 PM
12/06/15 01:49 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Man this is great news finally available👍👍pricing seem respectable and I'm sure in great hands they will be great heads a guy like Brett will get them where they need to be hopefully this will spur. Mopar to build a block... there are a ton small block heads available now👏👏👏👏... I also have heard significantly lower flow numbers.but I have not seen the version that's being sold. If some one can squeeze 350 cfm at a reasonable lift number is all you need
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1967657
12/11/15 12:21 PM
12/11/15 12:21 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
im curious to the custom piston deal with the 16* valve angle as well. what about header bolt up. will my hedman race headers bolt up to these? same ex flange as indy 360-1?
Re: SB Victor heads shipped...well, at least mine! [Re: B3422W5] #1967727
12/11/15 02:23 PM
12/11/15 02:23 PM
Mt Morris Michigan
Mt Morris Michigan
here you go, steve clukey 414 x block indy head. runs 8.90's in the street duster chassis. no exotics.
https://www.youtube.com/watch?v=5vMv5zjW9oI
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1967745
12/11/15 02:46 PM
12/11/15 02:46 PM
Mt Morris Michigan
Mt Morris Michigan
just spoke with hughes. maybe next week on the heads and not sure on rockers as far as availability. should make way more than my indy's.
Re: SB Victor heads shipped...well, at least mine! [Re: mopar dave] #1967940
12/11/15 09:13 PM
12/11/15 09:13 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Just one more thing that I don't get.
Threaded like hemi for head bolt stud....
Stock size 340 intake port.
I think casting has some potential but not the way it is right now.
Re: SB Victor heads shipped...well, at least mine! [Re: W5DART66] #1967942
12/11/15 09:17 PM
12/11/15 09:17 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
You can see oil drain back hole dumps right on head bolt hole.
Runs right on long wall of port on a wedge head long wall is real important.
Add this to the premium cost IMHO not a home run.
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1967949
12/11/15 09:21 PM
12/11/15 09:21 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I don't ever see them out performing a 360-1
Re: SB Victor heads shipped...well, at least mine! [Re: 80mirada] #1967975
12/11/15 09:55 PM
12/11/15 09:55 PM
Dayton, OH
1980volare Offline
My man card has just been revoked.
1980volare  Offline
Dayton, OH
Originally Posted By 80mirada
Jegs and Summit both claim to be able to ship a Mopar small block bare block this month. I hope this means we will be seeing some Victor headed SBMs soon.
12-18 month wait time. Waiting for foundery is what it lists when you try and order one, I wouldn't hold your hopes high on getting a new block, unless someone has some stashed somewhere.
Re: SB Victor heads shipped...well, at least mine! [Re: Quicktree] #1967978
12/11/15 09:56 PM
12/11/15 09:56 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
It's a much better casting than Indy stuff.
I just to see what I can do with raw head.
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1967986
12/11/15 10:01 PM
12/11/15 10:01 PM
Are those pics from SEMA or PRI? If so, that is the prototype head and a LOT has changed.
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor heads shipped...well, at least mine! [Re: W5DART66] #1967988
12/11/15 10:04 PM
12/11/15 10:04 PM
You can get a pro-port raw head right now, no waiting. Grab one and see what it will do!
Craig Scholl
CJD Automotive, LLC
Jacksonville, FL
904-400-1802
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1968011
12/11/15 10:28 PM
12/11/15 10:28 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
This is PRI and was told by engineer on this head this is the production part.
I told him about oil drain back into intake port last year maybe they looked into this.
But head last year at PRI the oil hole was machined and this looks cast??
Re: SB Victor heads shipped...well, at least mine! [Re: CJD AUTOMOTIVE] #1968013
12/11/15 10:31 PM
12/11/15 10:31 PM
PA
W5DART66 Offline
W5DART66  Offline
PA
Just go back and look at your heads.
On first page.
Still has poor oil drain hole and threads in head bolt hole.
