Re: SB Victor heads shipped...well, at least mine!
[Re: CJD AUTOMOTIVE]
#1963505
12/05/15 12:58 AM
12/05/15 12:58 AM
Quicktree
Westside. My shop works exclusively on late model Mopars. Don't mess much with the old stuff, unless you want EFI or a Gen 3 Hemi, etc. The www.CJDAUTOMOTIVE.com site always works. SRP is down for a revamp. Just haven't finished the updates and taking a break from the holiday calls that want recommendations and advice for Holley EFI, but never buy! very nice, I am surprised I have never heard of you guys. i'll have to get by one day. can you put a hellcat engine in our 300C?
[Re: J_BODY]
#1963507
12/05/15 01:01 AM
12/05/15 01:01 AM
Quicktree
man..... sold my W5 stuff off in 2012 so I could get these heads. I honestly can't believe that my W8 was up and running before SOMEONE finally got these heads!! I wouldn't worry to much about it. the performance is yet to be proven. I know what my 360-1s are capable of and will be surprised if these out perform them. and they definitely can't touch your 8s
#1963511
12/05/15 01:05 AM
12/05/15 01:05 AM
Posts: 106 Waterloo Iowa
80mirada
Waterloo Iowa
Jegs and Summit both claim to be able to ship a Mopar small block bare block this month. I hope this means we will be seeing some Victor headed SBMs soon.
#1963513
12/05/15 01:06 AM
12/05/15 01:06 AM
Posts: 4,302 Nebraska
72Swinger
Nebraska
Does this mean that Cuda is going to be making noise soon?
Mopar to the bone!!!
#1963545
12/05/15 02:12 AM
12/05/15 02:12 AM
Posts: 1,563 Janesville, WI
SpareParts
Janesville, WI
I hope for the best. That makes two of us! Gen 3 Hemi blocks won't take the power I make. I chose the R3 route for block durability at high cylinder pressures and HP. Finally a current head with great flow potential to make that power. I have no problem jumping in first. I've dealt with more Mopar race part fitment/machining/casting issues than I care to think about. I'll give the Eddy's a shot. Umm... how much power do you plan to make and what power adder? I assume if you are worried about G3 block integrity your doing an adder and 1600+hp? These are an oddball head IMO, better than the stock replacement type stuff but can't hang with the 15yr old W stuff (7,8,9) Though I am anxious to see what people do with them... I don't see me beating on Eddies' door for em. Quicktree, pure curiosity what do you think your 360's are capable of?
[Re: SpareParts]
#1963621
12/05/15 08:10 AM
12/05/15 08:10 AM
Quicktree
I hope for the best. That makes two of us! Gen 3 Hemi blocks won't take the power I make. I chose the R3 route for block durability at high cylinder pressures and HP. Finally a current head with great flow potential to make that power. I have no problem jumping in first. I've dealt with more Mopar race part fitment/machining/casting issues than I care to think about. I'll give the Eddy's a shot. Umm... how much power do you plan to make and what power adder? I assume if you are worried about G3 block integrity your doing an adder and 1600+hp? These are an oddball head IMO, better than the stock replacement type stuff but can't hang with the 15yr old W stuff (7,8,9) Though I am anxious to see what people do with them... I don't see me beating on Eddies' door for em. Quicktree, pure curiosity what do you think your 360's are capable of? around 750hp
#1963635
12/05/15 10:46 AM
12/05/15 10:46 AM
Posts: 11,726 Portage,michigan
B3422W5
Portage,michigan
Going to take a stout build with lots of detail and tricks to make 750 with the Indy heads . Not on a dyno but based on actual track results. Trying to think if I have seen such a critter
[Re: B3422W5]
#1963654
12/05/15 11:52 AM
12/05/15 11:52 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
Going to take a stout build with lots of detail and tricks to make 750 with the Indy heads . Not on a dyno but based on actual track results. Trying to think if I have seen such a critter I think I seen one. Lol that's all I can say.
[Re: 72Swinger]
#1963728
12/05/15 01:33 PM
12/05/15 01:33 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Does this mean that Cuda is going to be making noise soon? Yep! Doing some extensive suspension updates on the car right now. The engine has been ready, just switching heads out. So should have it back on the dyno once the heads get back from Crower. BTW, this car is setup to compete in SCCA CAM T, OUSCA, NASA vintage iron, and will make some mile runs as well as visit Bonneville. Won't see too much drag racing with 355's at all four corners!
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
#1963733
12/05/15 01:42 PM
12/05/15 01:42 PM
one bad fish
bronx n.y
Does this mean that Cuda is going to be making noise soon? Yep! Doing some extensive suspension updates on the car right now. The engine has been ready, just switching heads out. So should have it back on the dyno once the heads get back from Crower. BTW, this car is setup to compete in SCCA CAM T, OUSCA, NASA vintage iron, and will make some mile runs as well as visit Bonneville. Won't see too much drag racing with 355's at all four corners! what year Cuda
[Re: SpareParts]
#1963734
12/05/15 01:44 PM
12/05/15 01:44 PM
Posts: 656 Florida
CJD AUTOMOTIVE
I run twin 72MM turbos. I have a 422 R3. It's already seen a tad over 1500 on the dyno with the old heads that were 200cc and 25 psi. I'm really hoping to see close to 1700 HP. Trying to get this turd to 280 mph at Bonneville, and with my .CD, I'll need every bit of that to even get close. I don't really see how they are considered odd ball. W stuff takes specific intakes, rockers, and headers. The Eddy stuff will be readily available and ready to run (for most people), using current combustion technology and airflow/airspeed modeling/testing. I see these surpassing W-stuff once they are played with. All those huge 400 CFM plus flow numbers on W stuff is at .800 plus. Those heads don't flow any better, and in some cases worse, under the curve to .600.
[Re: one bad fish]
#1963739
12/05/15 01:54 PM
12/05/15 01:54 PM
Posts: 656 Florida
CJD AUTOMOTIVE
'70. Have a build thread in the projects sections, just haven't updated in awhile.
[Re: B3422W5]
#1963793
12/05/15 03:17 PM
12/05/15 03:17 PM
Quicktree
Going to take a stout build with lots of detail and tricks to make 750 with the Indy heads . Not on a dyno but based on actual track results. Trying to think if I have seen such a critter I bet it can be done with a max effort build one of my sets flows 336 @ 700 on the bench for what ever thats worth. I think 700 is easy. I have seen well over 600 with (at the track)a set of indybrocks with a fairly mild roller set up.
[Re: 1967dartgt]
#1963828
12/05/15 04:34 PM
12/05/15 04:34 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Would like to see them get close to my w9s. Don't think the casting can support those kind of numbers. Out the box.... Lift Intake .050 39.3 .100 75.8 .150 116.1 .200 167.4 .250 207.6 .300 238.5 .350 267.5 .400 296.2 .450 320.9 .500 339.3 .550 348.5 .600 357.3 .650 362.4 .700 366.7 .750 371.1 .800 371.3
[Re: greendart408]
#1963858
12/05/15 05:44 PM
12/05/15 05:44 PM
Posts: 656 Florida
CJD AUTOMOTIVE
What is the actual runner volume?? 225cc
