Re: SB Victor heads shipped...well, at least mine!
[Re: greendart408]
#1963873
12/05/15 06:08 PM
12/05/15 06:08 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Are those flow #s from your bench or Hughes? Hughes, but confirmed by Rick Roberts at Edelbrock. He's the production engineer on this head. That was the earlier version. Said the production heads #'s are a little better. I tend to believe him. Don't forget these are raised port (.750) , offset intake, and the valve laid down 2 degrees. I'll have them on the bench soon enough and we will all know.
Craig Scholl CJD Automotive, LLC Jacksonville, FL www.CJDAUTOMOTIVE.com904-400-1802 "I own a Mopar. I already know it won't be in stock, won't ship tomorrow, and won't fit without modification"
[Re: CJD AUTOMOTIVE]
#1963932
12/05/15 07:28 PM
12/05/15 07:28 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Can't compare runner volume without figureing out the length of the runner, clearly the eddy is longer than normal. Also can't the W9 and indy for that matter be used with existing pistons? The eddy has different valve angles/locations meaning different pistons for sure, not that it is a bad thing if they flow more and make more HP just more $$$.
[Re: HotRodDave]
#1963992
12/05/15 08:56 PM
12/05/15 08:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Is this Victor head a 48* or 59* head... if its a 48* I dont see why you cant compare it to the W-9.. I got my W-9 pistons from CP.. they were VERY NICE and lite
#1964184
12/06/15 02:59 AM
12/06/15 02:59 AM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
Are those flow #s from your bench or Hughes? Hughes, but confirmed by Rick Roberts at Edelbrock. He's the production engineer on this head. That was the earlier version. Said the production heads #'s are a little better. I tend to believe him. Don't forget these are raised port (.750) , offset intake, and the valve laid down 2 degrees. I'll have them on the bench soon enough and we will all know. I have seen them also, have a hard time seeing those flow numbers out of a small port.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: 1967dartgt]
#1964345
12/06/15 01:49 PM
12/06/15 01:49 PM
Posts: 3,036 bean town ....Ca
WHITEDART
bean town ....Ca
Man this is great news finally available👍👍pricing seem respectable and I'm sure in great hands they will be great heads a guy like Brett will get them where they need to be hopefully this will spur. Mopar to build a block... there are a ton small block heads available now👏👏👏👏... I also have heard significantly lower flow numbers.but I have not seen the version that's being sold. If some one can squeeze 350 cfm at a reasonable lift number is all you need
In the 8s N/A.with Brett miller W8's 5.07 at 133 at 2700lb
[Re: 80mirada]
#1967975
12/11/15 09:55 PM
12/11/15 09:55 PM
Posts: 582 Dayton, OH
1980volare
My man card has just been revoked.
Dayton, OH
Jegs and Summit both claim to be able to ship a Mopar small block bare block this month. I hope this means we will be seeing some Victor headed SBMs soon. 12-18 month wait time. Waiting for foundery is what it lists when you try and order one, I wouldn't hold your hopes high on getting a new block, unless someone has some stashed somewhere.
#1967986
12/11/15 10:01 PM
12/11/15 10:01 PM
Posts: 656 Florida
CJD AUTOMOTIVE
Are those pics from SEMA or PRI? If so, that is the prototype head and a LOT has changed.
[Re: W5DART66]
#1967988
12/11/15 10:04 PM
12/11/15 10:04 PM
Posts: 656 Florida
CJD AUTOMOTIVE
It's a much better casting than Indy stuff.
I just to see what I can do with raw head. You can get a pro-port raw head right now, no waiting. Grab one and see what it will do!
#1968013
12/11/15 10:31 PM
12/11/15 10:31 PM
Posts: 1,784 PA
W5DART66
PA
Are those pics from SEMA or PRI? If so, that is the prototype head and a LOT has changed. Just go back and look at your heads. On first page. Still has poor oil drain hole and threads in head bolt hole.
