Engine Cooling
#195519
01/16/09 09:12 PM
01/16/09 09:12 PM
I have a 68 Charger, 451 stroker, factory air with Sanden compressor conversion,26" radiator, 727. I am considering converting the factory cooling clutch fan to a Flex-a-lite model 210 puller twin electric fan and shroud assembly. This is a street car that finds the strip a few times a year. The motor runs cool with or without the A/C in 90 degree temps. Does anyone have experience with this type of conversion?
Re: Engine Cooling
[Re: MoparforLife]
#195521
01/16/09 09:55 PM
01/16/09 09:55 PM
Posts: 571 Western NC
68Bullit
Western NC
leave well enough alone.
I totally agree. If you're already running cool in 90 degree weather then there's nothing more to ask of your cooling system. Hard to beat a good clutch fan/shroud setup
BTW, Welcome to Moparts!!! Got any pics of your 68'??????
Re: Engine Cooling
[Re: 68Bullit]
#195522
01/17/09 05:00 PM
01/17/09 05:00 PM
Posts: 6,183 Bridgeport, WV
Michael
Bridgeport, WV
Re: Engine Cooling
[Re: Michael]
#195524
01/17/09 05:15 PM
01/17/09 05:15 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
It's unanimous. If you are running a stroker in an AC carr, and it stays cool in hot weather, you are way ahead of most. I've seen countless guys try fan and rad "upgrades" with no improvement, or even losses in cooling capacity.
Re: Engine Cooling
[Re: dave571]
#195525
01/17/09 07:19 PM
01/17/09 07:19 PM
Posts: 6,516 Santa Cruz, California
Lefty
It's unanimous.
No reason to try and fix what's working fine already.
Re: Engine Cooling
[Re: Michael]
#195527
01/25/09 02:37 PM
01/25/09 02:37 PM
Thanks for the reply. Pretty much thought the same thing. Thought I might free up some horses!
