Engine Cooling #195519
01/16/09 09:12 PM
01/16/09 09:12 PM
Anonymous OP
Anonymous OP
I have a 68 Charger, 451 stroker, factory air with Sanden compressor conversion,26" radiator, 727. I am considering converting the factory cooling clutch fan to a Flex-a-lite model 210 puller twin electric fan and shroud assembly. This is a street car that finds the strip a few times a year. The motor runs cool with or without the A/C in 90 degree temps. Does anyone have experience with this type of conversion?
Re: Engine Cooling #195520
01/16/09 09:27 PM
01/16/09 09:27 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
leave well enough alone.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: Engine Cooling [Re: MoparforLife] #195521
01/16/09 09:55 PM
01/16/09 09:55 PM
Western NC
68Bullit Offline
68Bullit  Offline
Western NC
I totally agree. If you're already running cool in 90 degree weather then there's nothing more to ask of your cooling system. Hard to beat a good clutch fan/shroud setup
BTW, Welcome to Moparts!!! Got any pics of your 68'??????
Re: Engine Cooling [Re: 68Bullit] #195522
01/17/09 05:00 PM
01/17/09 05:00 PM
Bridgeport, WV
Michael Offline
Michael  Offline
Bridgeport, WV
Re: Engine Cooling [Re: Michael] #195523
01/17/09 05:14 PM
01/17/09 05:14 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Guys would kill to have a system working as well as yours is.
Re: Engine Cooling [Re: Michael] #195524
01/17/09 05:15 PM
01/17/09 05:15 PM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
It's unanimous.
If you are running a stroker in an AC carr, and it stays cool in hot weather, you are way ahead of most.
I've seen countless guys try fan and rad "upgrades" with no improvement, or even losses in cooling capacity.
Re: Engine Cooling [Re: dave571] #195525
01/17/09 07:19 PM
01/17/09 07:19 PM
Santa Cruz, California
Lefty Offline
Lefty  Offline
It's unanimous.
No reason to try and fix what's working fine already.
Re: Engine Cooling [Re: Lefty] #195526
01/17/09 09:24 PM
01/17/09 09:24 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Not to mention, going to electric fans is a big step away from any sense of originality.
Re: Engine Cooling [Re: Michael] #195527
01/25/09 02:37 PM
01/25/09 02:37 PM
Anonymous OP
Anonymous OP
Thanks for the reply. Pretty much thought the same thing. Thought I might free up some horses!
