78 diplomat chassis swap with 78 volare? #1927402
10/06/15 11:43 PM
10/06/15 11:43 PM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
I have heard that the front chassis and suspension and rear suspension from a diplomat will bolt up to a same year volare, sway bars and all. true?
4bbl If you can't hear it coming what's the point.......
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1927434
10/07/15 12:15 AM
10/07/15 12:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Yes.
Re: 78 diplomat chassis swap with 78 volare? [Re: Kern Dog] #1927849
10/07/15 05:56 PM
10/07/15 05:56 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
The only difference between F/J/M cars is the sheet metal.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1928045
10/07/15 11:11 PM
10/07/15 11:11 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I saw one member's car where he pulled the 4sp out of a F body and put it into a Diplomat. Everything fit like a glove.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1928054
10/07/15 11:22 PM
10/07/15 11:22 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Any yea F/M/J will swap to any other year, does not have to be same year.
But closer to 89 is better than closer to 76.
I put a 4 speed into an M body, a bit more involved than fit like a glove. But not much. The 4 speed was out of a 70 A body, but F/J/M's used the same type so that wasn't an issue. Primarily what was an issue is that by 87 (the year of my M) Chrysler quit punching the holes in various places for a manual transmission, so I found a 79 F body with a manual, a three speed in this case, and used it to make templates and as a source for most of the linkage, floor hump, clutch pedal assembly. Used an A body Hurst Indy shifter since I wasn't running an A833OD. Use a Dakota 3.9L flywheel cause they are cheap new. What wasn't new got rebuilt by me before I even started the swap, took me a Saturday to do it all.
Don't be the exception.
Re: 78 diplomat chassis swap with 78 volare? [Re: Supercuda] #1928129
10/08/15 01:32 AM
10/08/15 01:32 AM
Manitoba Canada
67autocross Offline
67autocross  Offline
Manitoba Canada
The last year M body that seems to have 4 speed sheet metal that I have come across was a 1981 Plymouth Caravelle.
Swapping out the power train is easy if you drop it out the bottom.
A new iron curtain drawn across the 49th parallel
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1928166
10/08/15 03:07 AM
10/08/15 03:07 AM
Phoenix - surface of the sun
nomore65BelvJim Offline
76 to 88 should interchange pretty much everything, suspension wise.
Just tore down an 88 Dippy. Most of it looked the same as the dozens of 76-80 F's I've torn down.
As said above, pretty much the same car under the skin with a few subtle differences.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1928278
10/08/15 11:51 AM
10/08/15 11:51 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Speaking of F bodies, does anyone know what happened to aspenandvolare.com?
Re: 78 diplomat chassis swap with 78 volare? [Re: TC@HP2] #1928833
10/09/15 03:01 AM
10/09/15 03:01 AM
Its back up and running.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1928928
10/09/15 11:40 AM
10/09/15 11:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
I've tried getting in an it won't recognize my username or password. I tried requesting a reset, but their random question validation keeps telling me my answer is wrong, despite trying it several different ways.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1929096
10/09/15 03:34 PM
10/09/15 03:34 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
Yea, I had issues too.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1929224
10/09/15 07:40 PM
10/09/15 07:40 PM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Ahh, had to re-register.
thanks Jim!
Re: 78 diplomat chassis swap with 78 volare? [Re: mopars4ever] #1929435
10/10/15 02:53 AM
10/10/15 02:53 AM
Your welcome Tony up
Did you get in OK?
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1929509
10/10/15 11:07 AM
10/10/15 11:07 AM
md
md
Yes, I had to re-register too.
Re: 78 diplomat chassis swap with 78 volare? [Re: 4bbl] #1933806
10/17/15 03:19 PM
10/17/15 03:19 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Outside of the mechanicals and body there are some changes in things like glass, certainly for both the F/M body coupes where the pre-80 and post-80 stuff is not completely interchangable.
