78 diplomat chassis swap with 78 volare?
#1927402
10/06/15 11:43 PM
10/06/15 11:43 PM
Posts: 163 Iowa,US
4bbl
Iowa,US
I have heard that the front chassis and suspension and rear suspension from a diplomat will bolt up to a same year volare, sway bars and all. true?
4bbl
If you can't hear it coming what's the point.......
Re: 78 diplomat chassis swap with 78 volare?
[Re: Kern Dog]
#1927849
10/07/15 05:56 PM
10/07/15 05:56 PM
Posts: 4,410 Michigan
MarkZ
Worthy
Worthy
The only difference between F/J/M cars is the sheet metal.
[Re: 4bbl]
#1928054
10/07/15 11:22 PM
10/07/15 11:22 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Any yea F/M/J will swap to any other year, does not have to be same year.
But closer to 89 is better than closer to 76.
I put a 4 speed into an M body, a bit more involved than fit like a glove. But not much. The 4 speed was out of a 70 A body, but F/J/M's used the same type so that wasn't an issue. Primarily what was an issue is that by 87 (the year of my M) Chrysler quit punching the holes in various places for a manual transmission, so I found a 79 F body with a manual, a three speed in this case, and used it to make templates and as a source for most of the linkage, floor hump, clutch pedal assembly. Used an A body Hurst Indy shifter since I wasn't running an A833OD. Use a Dakota 3.9L flywheel cause they are cheap new. What wasn't new got rebuilt by me before I even started the swap, took me a Saturday to do it all.
[Re: Supercuda]
#1928129
10/08/15 01:32 AM
10/08/15 01:32 AM
Posts: 1,074 Manitoba Canada
67autocross
Manitoba Canada
I put a 4 speed into an M body, a bit more involved than fit like a glove. But not much. The 4 speed was out of a 70 A body, but F/J/M's used the same type so that wasn't an issue. Primarily what was an issue is that by 87 (the year of my M) Chrysler quit punching the holes in various places for a manual transmission, so I found a 79 F body with a manual, a three speed in this case, and used it to make templates and as a source for most of the linkage, floor hump, clutch pedal assembly. Used an A body Hurst Indy shifter since I wasn't running an A833OD. Use a Dakota 3.9L flywheel cause they are cheap new. What wasn't new got rebuilt by me before I even started the swap, took me a Saturday to do it all. The last year M body that seems to have 4 speed sheet metal that I have come across was a 1981 Plymouth Caravelle. Swapping out the power train is easy if you drop it out the bottom.
A new iron curtain drawn across the 49th parallel
[Re: 4bbl]
#1928166
10/08/15 03:07 AM
10/08/15 03:07 AM
Posts: 16,844 Phoenix - surface of the sun
nomore65BelvJim
I have heard that the front chassis and suspension and rear suspension from a diplomat will bolt up to a same year volare, sway bars and all. true? 76 to 88 should interchange pretty much everything, suspension wise. Just tore down an 88 Dippy. Most of it looked the same as the dozens of 76-80 F's I've torn down. As said above, pretty much the same car under the skin with a few subtle differences.
[Re: 4bbl]
#1929096
10/09/15 03:34 PM
10/09/15 03:34 PM
Posts: 13,589 md
mopars4ever
md
