bracket racer transmission cooler? #1898794
08/25/15 01:05 AM
08/25/15 01:05 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
what's the pro/con to just by-passing a transmission cooler on a dedicated 10 second bracket car?
4bbl If you can't hear it coming what's the point.......
Re: bracket racer transmission cooler? [Re: 4bbl] #1898802
08/25/15 01:18 AM
08/25/15 01:18 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The one big problem with a bracket car is you want everything
the same on every run.. no cooler and the trans temp climbs
and it will change the stall point... put a large cooler on
it and dont worry about the trans
wave
Re: bracket racer transmission cooler? [Re: 4bbl] #1898835
08/25/15 02:53 AM
08/25/15 02:53 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
a 10 sec car would have a good hi stall so you'd be building up heat especially if you're good & are doing some rounds. they come around quicker once you've made the quarter finals. buy a good one with a fan.
Re: bracket racer transmission cooler? [Re: 4bbl] #1898918
08/25/15 10:33 AM
08/25/15 10:33 AM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I use the B&M Supercooler with the fan.
5.53 @ 125 1/8th on the launch control..more left in her!
Re: bracket racer transmission cooler? [Re: Eric] #1898936
08/25/15 11:04 AM
08/25/15 11:04 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
If you really want to upgrade your transmission cooling system add a cooler and one of these. One of my racing Friends at Pittsburgh Raceway Park offers these.
http://jonestransmissionpumps.com/
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: bracket racer transmission cooler? [Re: pittsburghracer] #1898952
08/25/15 11:49 AM
08/25/15 11:49 AM
NJ
JCCuda Offline
JCCuda  Offline
NJ
Not to hijack this post but what are the thoughts on placing a trans cooler under the car close to the trans as opposed to in front of the radiator?
Re: bracket racer transmission cooler? [Re: JCCuda] #1898979
08/25/15 12:41 PM
08/25/15 12:41 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Is there room to mount one there with a fan on it? It certainly won't get any airflow if it's under the car
**Photobucket sucks**
Re: bracket racer transmission cooler? [Re: 4bbl] #1899137
08/25/15 03:54 PM
08/25/15 03:54 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Yes it certainly DOES get airflow under the car. I have done it quite a few times. I know that DVW’s NSS car is mounted in this way.
My car because of the turbo sometimes has to be on the transbrake for a long time to spool it up. (Especially with the old tight converter)
I had one BIG tube/fin in front of my radiator (18x18?) but it wasn’t enough. Added a second smaller 10 x 8 under the car just behind the front cross member and that helped more. Took the trans blanket off and switched to a CSR shield, and that was better yet.
But going round robin (sometimes in multiple classes) it would still get the trans fluid NUCLEAR hot.
I had a 48RE deep steel pan on the car, and I switched to the B&M deep aluminum cast pan with fins on it. I honestly did it because the stamped pan was old/beat and leaked. But surprisingly this had a HUGE impact on my ability to keep the trans temp down.
Now I haven’t had any issues with it at all…
Re: bracket racer transmission cooler? [Re: 4bbl] #1899274
08/25/15 07:31 PM
08/25/15 07:31 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
my trans cooler is down the back of my racecar by the diff. it has a fan attached & overheating is not a problem. it also helps with weight distribution & with the fan running, it blows my burnout smoke away making my burnouts look more impressive.
Re: bracket racer transmission cooler? [Re: rebel] #1900793
08/28/15 12:31 AM
08/28/15 12:31 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
All good info, Probably go with the fan equiped at rear of car, and a temp gauge and auto temp control for sure.
Re: bracket racer transmission cooler? [Re: rebel] #1900798
08/28/15 12:37 AM
08/28/15 12:37 AM
Iowa,US
4bbl Offline OP
4bbl  Offline OP
Iowa,US
thanks all good info, I prob go with the fan equiped at rear of car. temp gauge and auto temp switch.
Re: bracket racer transmission cooler? [Re: 4bbl] #1900860
08/28/15 02:07 AM
08/28/15 02:07 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
when you mount your temp gauge, make sure its on the return from the cooler or in the pan. the first gauge i fitted was going to the cooler, when you come off the transbrake it went around so far it knocked the needle off the gauge, kinda ruined a good gauge that did.
