bracket racer transmission cooler?
#1898794
08/25/15 01:05 AM
08/25/15 01:05 AM
Posts: 163 Iowa,US
4bbl
Iowa,US
what's the pro/con to just by-passing a transmission cooler on a dedicated 10 second bracket car?
4bbl
If you can't hear it coming what's the point.......
Re: bracket racer transmission cooler?
[Re: 4bbl]
#1898802
08/25/15 01:18 AM
08/25/15 01:18 AM
Posts: 52,972 Romeo MI
MR_P_BODY
what's the pro/con to just by-passing a transmission cooler on a dedicated 10 second bracket car? The one big problem with a bracket car is you want everything the same on every run.. no cooler and the trans temp climbs and it will change the stall point... put a large cooler on it and dont worry about the trans ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: 4bbl]
#1898918
08/25/15 10:33 AM
08/25/15 10:33 AM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I use the B&M Supercooler with the fan.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1898936
08/25/15 11:04 AM
08/25/15 11:04 AM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
If you really want to upgrade your transmission cooling system add a cooler and one of these. One of my racing Friends at Pittsburgh Raceway Park offers these. http://jonestransmissionpumps.com/
[Re: JCCuda]
#1898979
08/25/15 12:41 PM
08/25/15 12:41 PM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
Is there room to mount one there with a fan on it? It certainly won't get any airflow if it's under the car
**Photobucket sucks**
[Re: rebel]
#1900793
08/28/15 12:31 AM
08/28/15 12:31 AM
Posts: 163 Iowa,US
4bbl
Iowa,US
All good info, Probably go with the fan equiped at rear of car, and a temp gauge and auto temp control for sure.
4bbl
[Re: rebel]
#1900798
08/28/15 12:37 AM
08/28/15 12:37 AM
Posts: 163 Iowa,US
4bbl
Iowa,US
thanks all good info, I prob go with the fan equiped at rear of car. temp gauge and auto temp switch.
4bbl
