Re: Valve relief pockets as gas ports???
[Re: 1976 Aspen]
#189598
01/13/09 11:55 AM
01/13/09 11:55 AM
Posts: 3,635 Oakland, MI
dizuster
Oakland, MI
My machinist said he's done this many times with big block chevy's and we all know they're alot more prone to detonation than our stuff.
So the guy that screwed them up, and really should buy you a new set says they're fine huh?...
I guess that's the part of the story that I don't get the most? Why isn't he just buying you a new set? I know you're not racing in MN yet!!
#189599
01/13/09 02:19 PM
01/13/09 02:19 PM
Posts: 75,082 U.S.S.A.
JohnRR
U.S.S.A.
in any case i do find it interesting that even with all the people telling you all the bad things that can happen, your still willing to chance trashing a motor.
That's because he was FISHING for someone to agree with what he wanted to do .
[Re: JohnRR]
#189601
01/13/09 03:22 PM
01/13/09 03:22 PM
Posts: 149 Cleveland Ohio
Discoquik
Cleveland Ohio
They are going to lead to trouble. There are many reasons not to recut, redress, or alter grooves. The pocket can be altered but with caution as proven here. The manufacturer would have known if the part could be cut for the desired pocket if the diameter of the valve was given. I don't know the details but in our cases we typically look at the computer model and can actually "measure" the changes and know if it is ok. But this is dependent on accurate information and communication of what is going to be done. I would look into a new set of pistons and order them with the ring stack moved down on the part. Vic Ellinger vellinger@wiseco.comWiseco Performance Products
[Re: B G Racing]
#189604
10/16/09 12:26 PM
10/16/09 12:26 PM
Posts: 345 Arkansas
JoWeTu_6
Arkansas
I know a cheap guy that runs a stable of Maxwedge cars that had some hillbilly shop weld up a couple similar to that with some high silicone aluminum rod and the lasted longer than his engine did.If it's affordable buy a new set,if not find a hillbilly shop like the other guy did.I would not run them like that,the hole would only get bigger.It's not like a gas port that is a small hole that is in the meaty part of the piston.
[Re: 1976 Aspen]
#189605
10/16/09 12:30 PM
10/16/09 12:30 PM
dizuster
Oakland, MI
You know, if you're a good enough racer to be the track champion, all the more reason to do everything you can to prevent an untimely failure. If Joe Schmo breaks a motor in the 1st round who cares. But I would think someone chasing a championship would care. Glad to hear that even though your machinist screwed up your pistons, and talked you into using them anyway, that you didn't get burned from it. Newbie lesson... "Everybody get's lucky sometimes."
[Re: 1976 Aspen]
#189606
10/16/09 12:43 PM
10/16/09 12:43 PM
Posts: 705 Michigan
Hemiroid
Well, for all you gurus who thought my pistons were junk, they made it through the season and I'm going to run another one on them. I got 212 1/4 mile passes on them and oh, did I mention, I won the track championship with them??? So to all the newbies on here, take all the advice on this board with a grain of salt
Hmm, so you're saying that because your machinist ruined a set of pistons and you decided to run them anyway and got away with it that you got bad advice?
You probably would have been the first guy to come back and complain about those that said it's ok it the piston shattered, lost the pin. Then the rod sawed a hole in the liner in that hole and cut the cam in half. Then the rest of the motor came apart and oiled down your slicks and you stuck it in the wall or in the side of someone else's car.
You took a chance, disregarded the advice of a lot of good engine builders and got away with it. Doesn't make you smart, just lucky. You were given the right advice, whether you realize it or not.
Congratulations on your championship.
[Re: 1976 Aspen]
#189610
10/16/09 05:29 PM
10/16/09 05:29 PM
JohnRR
U.S.S.A.
If you and your machinist are smarter than everyone else why did you even bother asking in the first place ?
Have you pulled a head to see how much bigger the hole is? With your razzing I'm guessing you would have posted the picture to further your case.
[Re: 1976 Aspen]
#189612
10/17/09 11:20 AM
10/17/09 11:20 AM
JohnRR
U.S.S.A.
Dizuster- Sorry, but new pistons were not in the budget at the time
I'm not gloating, razzing, or saying I'm smarter than anybody else. 75% of you probably know more about this than me. I just figured everybody would wanna know how it ended up. I'm pulling the heads to redo the valve guides and I'll be sure to post a picture at that time. Stay tuned!!!
You're not ??? Did someone else post this using your account ?
otherwise waiting for the pictures
