Re: Valve relief pockets as gas ports???
[Re: 1976 Aspen]
#189566
01/10/09 07:12 PM
01/10/09 07:12 PM
Posts: 4,330 Lynchburg, VA
Leon441
Lynchburg, VA
I wouldn't run that junk. You pressurize the land between top and second ring. This is going to happen. The hole in your picture is larger than all the holes put together in a gas ported piston. When you gas port you do not drill holes near the intake valve releif as it is the weakest area in the top of the piston. Like someone said you would want to gap the heck out of the second ring because you will want to blow all that pressure out of the land. If you run it and get away with it fine. If you don't. What will happen is the top of the piston next to the valve relieg will bend up from pressure. Then it will finally reach the head. When it does the piston smacks the head bended this problem back down. This process will continue until the piston breaks sending this chunk into your ports bending valves. If you are lucky it will shoot out of the exhaust. If you are not so lucky it will go by an intake bend it, [Edited by Moparts - Keep it clean] the seat and get into the intake manifold and find another cylinder or two to screw up. Don't do it.
Leon
[Re: 1976 Aspen]
#189569
01/10/09 07:47 PM
01/10/09 07:47 PM
Posts: 1,113 Lost in Pooler, GA
Gumbydammit
Lost in Pooler, GA
$700 pistons vs. a $4000 short block. ( I'm guessing) I'm not a lucky guy, so I'd be changing the pistons now.
I'm Gumby dammit!
[Re: 1976 Aspen]
#189570
01/11/09 06:32 PM
01/11/09 06:32 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
yes it will start to lift the land at about 50 passes or so,,, usually pistons come with large enough pockets to fit that large of a valve,,, you made the pocket 2.150? or 2.200? i still think you have way too much radial clearance,, and thats where your problem came from,,, and if the guy notching them didnt know that was going to happen until he seen a hole,, dont go back to him.... how does that go??? measure twice cut once??
[Re: dthemi]
#189572
01/11/09 07:03 PM
01/11/09 07:03 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I'm thinking this is only 1 piston, so IF you did go greater than needed on the radial clearance you would be lucky.... and only have to buy 1 piston
[Re: MR_P_BODY]
#189573
01/11/09 07:42 PM
01/11/09 07:42 PM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
Mike, he said all 8 had that hole. Why the machinest didnt stop after the first, I dont know.
As stated before the hole you see now is only going to get bigger. Close to the hole its paper thin I bet. If you stuck a pointed tip in the hole it would probably slot out abit pretty easy.
Depending on the combo, you could be okay for awhile. Mild/longer Wild/short JMO mike
[Re: Sport440]
#189575
01/11/09 08:15 PM
01/11/09 08:15 PM
MR_P_BODY
I just read that he did all 8......
