Page 2 of 3 1 2 3
Re: Valve relief pockets as gas ports??? [Re: 540dust] #189578
01/11/09 11:16 PM
01/11/09 11:16 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
I know a guy that welded the notches before too, but the hole was thru the bottom not to the ring groove.
The ring groove can be re-dressed
Re: Valve relief pockets as gas ports??? [Re: B G Racing] #189579
01/11/09 11:28 PM
01/11/09 11:28 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Really? I called Diamond getting ring grooves re-cut and they told me no way....
I'd be worried about warping the ring land groove. Most good pistons today are so tight to start with, it wouldn't take much...
I'd be getting a new set from whoever screwed them up when they cut them.
I mean come on, cutting a hole in 1 is a mistake, cutting all 8 is a joke...
Re: Valve relief pockets as gas ports??? [Re: dizuster] #189580
01/11/09 11:58 PM
01/11/09 11:58 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
What's so hard about cutting ring lands?We have re-cut them to go to a thicker ring and have also relocated the ring lands.The rings is what conforms to the bore.The top portion of the piston is smaller than the bore.Many pistons are cam ground with only the skirt or thrust sides conforming to the bore,with specific clearences.
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189581
01/12/09 12:09 AM
01/12/09 12:09 AM
i wouldn't run them. adding radial clearance is one thing, but milling .065 deeper should give you enough room for an .800 lift cam. they look a lot deeper than that.
i know it's not what you want to hear but, i think you have 8 new paperweights.
Re: Valve relief pockets as gas ports??? #189582
01/12/09 12:19 AM
01/12/09 12:19 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If your going to toss them,send them to us,Curt Jr and Chaz can practice their barnyard techniques.
Re: Valve relief pockets as gas ports??? [Re: B G Racing] #189583
01/12/09 09:12 AM
01/12/09 09:12 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That is exactly what Diamond said they would not do. I called them because I was thinking about buying a set of pistons a guy had, but they were metric rings, and I wanted standard 1/16" stuff. I told Diamond I already had the pistons and I wanted to send them back to get the rings re-cut. They said they absolutely would not do that?
Should have bought them and sent them to you!
Re: Valve relief pockets as gas ports??? [Re: dizuster] #189584
01/12/09 09:39 AM
01/12/09 09:39 AM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Some pistons are not concentric enough to chuck up with out the centering plug left on the top of the piston,once the piston has been machined the stub is knocked off and the top is finished.To re-chuck it can be a pita on some but with a little effort anything can be done.
Re: Valve relief pockets as gas ports??? [Re: B G Racing] #189585
01/12/09 07:18 PM
01/12/09 07:18 PM
Roseau, MN
1976 Aspen Offline OP
Roseau, MN
Well, despite everybody's advice and opinions, I've decided to run it the way they are. My machinist said he's done this many times with big block chevy's and we all know they're alot more prone to detonation than our stuff. Thanks for all the reply's and I'll keep you updated on when it makes a mess of things
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189586
01/12/09 09:00 PM
01/12/09 09:00 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
Sorry, I would have a serious problem with those slug's,,,,I just hope I am never in the other lane against you.
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189587
01/12/09 09:11 PM
01/12/09 09:11 PM
here's a silly question. it's clearly obvious that one of the holes connects with the ring land. where does the other one go??? it's too far inward to connect to the ring land. it looks like it would just go through the top and come out the bottom of the piston near the pin.
in any case i do find it interesting that even with all the people telling you all the bad things that can happen, your still willing to chance trashing a motor.
Re: Valve relief pockets as gas ports??? [Re: dartman366] #189588
01/12/09 09:25 PM
01/12/09 09:25 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
There are tons of motors out there running way worse than that, and they just don't know it yet.
Obviously it would be the right thing to do to get new ones, and had we done that to a customers pistons, we'd buy you a new set along with an apology for delaying you. but if that were all that was between me and going to the track because of time, or budget constraints I'd pound'm in and head on out.
Alright I'm ready for my beating now
Re: Valve relief pockets as gas ports??? [Re: dthemi] #189589
01/12/09 09:56 PM
01/12/09 09:56 PM
Roseau, MN
Roseau, MN
Dartman- It's not like my motor is going to saw itself in half going down the track
DRAM- There is only one little hole. I have .187 in the thinnest spot to make an actual hole in the top of the piston. And no offense to you or anybody else, I've learned to take most information, advice, and opinions with a grain of salt on this board.
dthemi- I can understand where you're coming from. I'll keep everybody posted when, or if, it decides to break.
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189590
01/12/09 10:12 PM
01/12/09 10:12 PM
maybe i'm just seeing a reflection or something. it looks like 3 different holes.
Re: Valve relief pockets as gas ports??? #189591
01/12/09 10:14 PM
01/12/09 10:14 PM
Roseau, MN
Roseau, MN
DRAM, you're seeing a reflection. The only hole is on the intake relief furthest to the left. The others are just camera glare. Whatcha think about it now???
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189592
01/12/09 10:22 PM
01/12/09 10:22 PM
what's the depth of the valve pocket and were they shelf stock CP pistons you started with?
Re: Valve relief pockets as gas ports??? #189593
01/12/09 10:27 PM
01/12/09 10:27 PM
Roseau, MN
Roseau, MN
The pocket depth from the top of the piston to the deepest part of the pocket??? No, they were custom CP's ordered from SDSS when he did my stroker kit last winter.
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189594
01/12/09 10:29 PM
01/12/09 10:29 PM
yes, and if you know, how deep were they before they were cut?
Re: Valve relief pockets as gas ports??? #189595
01/12/09 11:15 PM
01/12/09 11:15 PM
Roseau, MN
Roseau, MN
They're about .250 deep now and they were like .190 deep I think.
Re: Valve relief pockets as gas ports??? [Re: 1976 Aspen] #189596
01/13/09 12:43 AM
01/13/09 12:43 AM
i'm not 100% positive but i think their std. smallblock valve reliefs are something like .230 intake and .190 exhaust. being a custom set they might have been deeper than that already.
to answer your other question, no, i still wouldn't run them. that's a very large hole. eventually the ring gap will line up with that hole and may actually get stuck there due to the pressure escaping. it's not anything like a normal gas port. good luck with them, i hope it doesn't cost you a motor down the road. no doubt it'll run, for how long is the question.
Re: Valve relief pockets as gas ports??? #189597
01/13/09 09:43 AM
01/13/09 09:43 AM
State College, PA
RyanJ Offline
moparts member
RyanJ  Offline
moparts member
State College, PA
My CP spec sheet shows them being .280" intake .250" exhaust when I had them made
Page 2 of 3 1 2 3
