Cylinder Head Studs #1852231
06/18/15 11:45 PM
06/18/15 11:45 PM
NY
Beep Beep Offline OP
NY
Hi,
I am putting together a 499 cube street stroker motor that should be making about 600hp. Should I be looking at cylinder head studs. I currently am using ARP bolts. Does anyone know the correct part number for studs when using stealth heads or edelbrock RPM heads? I think it's Arp 145-4206.
I would also like to use studs on the rocker shafts. I can't find a kit for these. I think I need to buy individual studs. What are the required lengths I would need?
Re: Cylinder Head Studs [Re: Beep Beep] #1852242
06/19/15 12:04 AM
06/19/15 12:04 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hughs Engines has a nice hold down kit with studs, nuts, washers, and billet steel holddowns.
They also have the studs you want. I chose not go with studs on my 493 just because if I needed to remove the heads in the car it would be easier. I used the Manley head bolts that came with my heads.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Cylinder Head Studs [Re: Beep Beep] #1852251
06/19/15 12:13 AM
06/19/15 12:13 AM
NY
NY
Gus,
Very good point. I might have to keep using the head bolts. I don't think I can remove the passenger side head when using studs.
Re: Cylinder Head Studs [Re: Beep Beep] #1852355
06/19/15 02:32 AM
06/19/15 02:32 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
Originally Posted By Beep Beep
Gus,
I went with bolts as well for this very reason. I need to look into the Hughes rocker hold downs as they look very nice!
'63 Dodge 330
11.19 @ 121 mph
Re: Cylinder Head Studs [Re: Beep Beep] #1852419
06/19/15 10:25 AM
06/19/15 10:25 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Most ARP studs can easily be removed with a 3/16 allen wrench.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Cylinder Head Studs [Re: Beep Beep] #1852421
06/19/15 10:32 AM
06/19/15 10:32 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
My combo is very close to yours; street/strip 499", Edelbrocks, 11:1, flat tappet solid, 520RWHP. Using bolts, not studs for nearly 9 years with no problems.
Master, again and still
Re: Cylinder Head Studs [Re: Beep Beep] #1852627
06/19/15 04:56 PM
06/19/15 04:56 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
My 440 running 12.5 domes uses ARP bolts with Stealths.Been on at least 6 years now.Lots of street miles and some 1/4 passes.No problems.Rocky
Chrysler Firepower
Re: Cylinder Head Studs [Re: Beep Beep] #1852800
06/19/15 09:11 PM
06/19/15 09:11 PM
Gus,
You might be able to remove the lower heads studs in the car work shruggy One thing about the head studs and headers is if you have a set of big tube headers the head studs may hit the header flanges scope, been there done that runaway I run head bolts on my current bracket car because of that issue shruggy
Re: Cylinder Head Studs [Re: Beep Beep] #1852935
06/20/15 12:14 AM
06/20/15 12:14 AM
NY
NY
Thanks everyone for the great feedback. I will stick with the bolts.
