Re: Cylinder Head Studs
[Re: Beep Beep]
#1852242
06/19/15 12:04 AM
06/19/15 12:04 AM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hughs Engines has a nice hold down kit with studs, nuts, washers, and billet steel holddowns. They also have the studs you want. I chose not go with studs on my 493 just because if I needed to remove the heads in the car it would be easier. I used the Manley head bolts that came with my heads. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Beep Beep]
#1852355
06/19/15 02:32 AM
06/19/15 02:32 AM
Posts: 4,704 Wichita
GY3
Wichita
Gus,
Very good point. I might have to keep using the head bolts. I don't think I can remove the passenger side head when using studs. I went with bolts as well for this very reason. I need to look into the Hughes rocker hold downs as they look very nice!
[Re: Beep Beep]
#1852419
06/19/15 10:25 AM
06/19/15 10:25 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most ARP studs can easily be removed with a 3/16 allen wrench.
[Re: Beep Beep]
#1852421
06/19/15 10:32 AM
06/19/15 10:32 AM
Posts: 12,301 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My combo is very close to yours; street/strip 499", Edelbrocks, 11:1, flat tappet solid, 520RWHP. Using bolts, not studs for nearly 9 years with no problems.
Master, again and still
[Re: Beep Beep]
#1852627
06/19/15 04:56 PM
06/19/15 04:56 PM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
My 440 running 12.5 domes uses ARP bolts with Stealths.Been on at least 6 years now.Lots of street miles and some 1/4 passes.No problems.Rocky
Chrysler Firepower
[Re: Beep Beep]
#1852800
06/19/15 09:11 PM
06/19/15 09:11 PM
Posts: 43,315 Bend,OR USA
Cab_Burge
Gus,
Very good point. I might have to keep using the head bolts. I don't think I can remove the passenger side head when using studs. You might be able to remove the lower heads studs in the car ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) One thing about the head studs and headers is if you have a set of big tube headers the head studs may hit the header flanges ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) , been there done that ![runaway runaway](/ubbthreads/images/graemlins/custom/runaway.gif) I run head bolts on my current bracket car because of that issue ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
