Re: Cylinder Head Studs
[Re: Beep Beep]
#1852242
06/19/15 12:04 AM
06/19/15 12:04 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Hughs Engines has a nice hold down kit with studs, nuts, washers, and billet steel holddowns. They also have the studs you want. I chose not go with studs on my 493 just because if I needed to remove the heads in the car it would be easier. I used the Manley head bolts that came with my heads. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Beep Beep]
#1852355
06/19/15 02:32 AM
06/19/15 02:32 AM
Posts: 4,687 Wichita
GY3
Wichita
Gus,
Very good point. I might have to keep using the head bolts. I don't think I can remove the passenger side head when using studs. I went with bolts as well for this very reason. I need to look into the Hughes rocker hold downs as they look very nice!
[Re: Beep Beep]
#1852419
06/19/15 10:25 AM
06/19/15 10:25 AM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Most ARP studs can easily be removed with a 3/16 allen wrench.
[Re: Beep Beep]
#1852421
06/19/15 10:32 AM
06/19/15 10:32 AM
Posts: 12,162 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My combo is very close to yours; street/strip 499", Edelbrocks, 11:1, flat tappet solid, 520RWHP. Using bolts, not studs for nearly 9 years with no problems.
Master, again and still
[Re: Beep Beep]
#1852627
06/19/15 04:56 PM
06/19/15 04:56 PM
Posts: 21,076 Niles , Ohio
therocks
Niles , Ohio
My 440 running 12.5 domes uses ARP bolts with Stealths.Been on at least 6 years now.Lots of street miles and some 1/4 passes.No problems.Rocky
Chrysler Firepower
[Re: Beep Beep]
#1852800
06/19/15 09:11 PM
06/19/15 09:11 PM
Posts: 43,228 Bend,OR USA
Cab_Burge
Gus,
Very good point. I might have to keep using the head bolts. I don't think I can remove the passenger side head when using studs. You might be able to remove the lower heads studs in the car One thing about the head studs and headers is if you have a set of big tube headers the head studs may hit the header flanges , been there done that I run head bolts on my current bracket car because of that issue
