A833 shifter lever stud replacement
#1840914
06/03/15 10:34 PM
06/03/15 10:34 PM
Posts: 1,180 clarks summit pa
73cuda340
clarks summit pa
Finally found my shifting problem with my 4 speed. The rectangular part of the shifter lever stud that sticks out of the side cover and the operating lever slides onto is rounded off and the operating lever has slop in it. Is there a way to just replace that part or do I have to pull the side cover off and change the whole lever assembly?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip,
(JA5) Silver Frost Metallic
1973 Challenger Rallye 340
1985 W150 Power Ram prospector
1986 Camaro IROC-Z 305 tpi
Re: A833 shifter lever stud replacement
[Re: 70HemiGTX]
#1840928
06/03/15 10:40 PM
06/03/15 10:40 PM
73cuda340
clarks summit pa
Thanks for the quick response
[Re: 73cuda340]
#1841054
06/04/15 12:24 AM
06/04/15 12:24 AM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
You can get replacement shift shafts from Passon Performance just send your old ones to him and he will send remanufactured ones that will work like new. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Dan Brewer]
#1842581
06/05/15 11:44 PM
06/05/15 11:44 PM
73cuda340
clarks summit pa
Thanks for the responses. I have a spare 4 speed so I'm just going to use the one from that transmission.
[Re: 73cuda340]
#1842695
06/06/15 02:38 AM
06/06/15 02:38 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I am a big fan of steel shift forks if you are going to beat on it. Too many night driving home stuck in 3rd gear for me to use the stock stuff.
