A833 shifter lever stud replacement #1840914
06/03/15 10:34 PM
06/03/15 10:34 PM
clarks summit pa
73cuda340 Offline OP
clarks summit pa
Finally found my shifting problem with my 4 speed. The rectangular part of the shifter lever stud that sticks out of the side cover and the operating lever slides onto is rounded off and the operating lever has slop in it. Is there a way to just replace that part or do I have to pull the side cover off and change the whole lever assembly?
1973 Cuda 528 all aluminum Hemi, 4 speed, 3.23 Sure-Grip, (JA5) Silver Frost Metallic 1973 Challenger Rallye 340 1985 W150 Power Ram prospector 1986 Camaro IROC-Z 305 tpi
Re: A833 shifter lever stud replacement [Re: 73cuda340] #1840920
06/03/15 10:36 PM
06/03/15 10:36 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Remove side cover and replace it.
Re: A833 shifter lever stud replacement [Re: 70HemiGTX] #1840928
06/03/15 10:40 PM
06/03/15 10:40 PM
clarks summit pa
clarks summit pa
Thanks for the quick response
Re: A833 shifter lever stud replacement [Re: 73cuda340] #1841054
06/04/15 12:24 AM
06/04/15 12:24 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You can get replacement shift shafts from Passon Performance just send your old ones to him and he will send remanufactured ones that will work like new.
Gus beer
64 Plymouth Savoy
Dana 60
Re: A833 shifter lever stud replacement [Re: fourgearsavoy] #1841282
06/04/15 11:27 AM
06/04/15 11:27 AM
Ohio
Dan Brewer Offline
Dan Brewer  Offline
Ohio
A833 4-speeds, parts & services
http://www.brewersperformance.com/
Re: A833 shifter lever stud replacement [Re: Dan Brewer] #1842581
06/05/15 11:44 PM
06/05/15 11:44 PM
clarks summit pa
clarks summit pa
Thanks for the responses. I have a spare 4 speed so I'm just going to use the one from that transmission.
Re: A833 shifter lever stud replacement [Re: 73cuda340] #1842695
06/06/15 02:38 AM
06/06/15 02:38 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
I am a big fan of steel shift forks if you are going to beat on it. Too many night driving home stuck in 3rd gear for me to use the stock stuff.
