Digital multimeter recommendations please
#1812619
04/26/15 10:51 PM
04/26/15 10:51 PM
Posts: 2,733 541 slobovia
A990
541 slobovia
Is there a decent one under a hundred bucks or so? I cant justify a Fluke, so an alternative would be appreciated I'm so confused
Re: Digital multimeter recommendations please
[Re: OzHemi]
#1812650
04/26/15 11:17 PM
04/26/15 11:17 PM
A990
541 slobovia
Justify a Fluke...buy it once, and it will last you forever.
(Long time Fluke owner personally)
awww man just had to do that didnt you. I've pulled lots of triggers lately
[Re: A990]
#1812651
04/26/15 11:19 PM
04/26/15 11:19 PM
Posts: 104,346 Garden Grove, CA
OzHemi
Penguin-hating Ginger
Garden Grove, CA
I bought mine in the early - mid 90's or so. Saved up for it, but knew it would last me. (If you didn't mind analog, vintage stuff is good too..I have a bit of that around too, just for the heck of it. )
[Re: OzHemi]
#1812678
04/26/15 11:39 PM
04/26/15 11:39 PM
Posts: 1,822 Colorado
denfireguy
Colorado
I have a Simpson 260 that is older than all your Flukes. Analog to be sure. But all voltages, resistances and current measurements are analog anyway with no +/- 1 of the last digit error of all digital meters. It is also easier to tune for maximum with a analog meter. I have 7 of the meters Harbor Freight gives away. Disposable but can be in the back of all my vehicles with four spares. I blew up a very expensive Beckman digital meter when I arced over a high voltage circuit years ago. I gave up a lab grade meters for daily use. I know where to borrow one if I need it. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: Alaskan_TA]
#1812683
04/26/15 11:42 PM
04/26/15 11:42 PM
OzHemi
Garden Grove, CA
Revolting perhaps, but I had too. You won't find any resistance from me...
[Re: A990]
#1812693
04/26/15 11:49 PM
04/26/15 11:49 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
Check on Ebay, you can find some good deals on used ones there. I have been using the same Blue-Point meter for 15 years until it got crushed. Got the same model on E-Bay that looked new for $50.
The only Carbs I care about are under the hood!
[Re: Alaskan_TA]
#1812697
04/26/15 11:50 PM
04/26/15 11:50 PM
OzHemi
Garden Grove, CA
Time for some quiet meditation.
ohm
...etc You are lucky I have the capacity for all the puns.
