Page 1 of 4 1 2 3 4
Digital multimeter recommendations please #1812619
04/26/15 10:51 PM
04/26/15 10:51 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
Is there a decent one under a hundred bucks or so? I cant justify a Fluke, so an alternative would be appreciated
I'm so confused panic
Re: Digital multimeter recommendations please [Re: A990] #1812639
04/26/15 11:07 PM
04/26/15 11:07 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Justify a Fluke...buy it once, and it will last you forever.
(Long time Fluke owner personally)
Re: Digital multimeter recommendations please [Re: A990] #1812647
04/26/15 11:14 PM
04/26/15 11:14 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
I agree, Fluke. I bought mine new when I was 21 years old & 26 years later it is a time tested friend.
Re: Digital multimeter recommendations please [Re: OzHemi] #1812650
04/26/15 11:17 PM
04/26/15 11:17 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
awww man just had to do that didnt you. I've pulled lots of triggers lately
Re: Digital multimeter recommendations please [Re: A990] #1812651
04/26/15 11:19 PM
04/26/15 11:19 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I bought mine in the early - mid 90's or so. Saved up for it, but knew it would last me.
(If you didn't mind analog, vintage stuff is good too..I have a bit of that around too, just for the heck of it. biggrin )
Re: Digital multimeter recommendations please [Re: A990] #1812652
04/26/15 11:21 PM
04/26/15 11:21 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
<peer pressure> Dooooooooo it! </peer pressure>
laugh
Re: Digital multimeter recommendations please [Re: OzHemi] #1812661
04/26/15 11:27 PM
04/26/15 11:27 PM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
laugh
LOL
Re: Digital multimeter recommendations please [Re: A990] #1812669
04/26/15 11:31 PM
04/26/15 11:31 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Bought my Fluke in the early 90's but I was a sparky and used it a lot. Still going strong.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Digital multimeter recommendations please [Re: A990] #1812674
04/26/15 11:36 PM
04/26/15 11:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
I have a Fluke 80 I got from work a long time ago, I also have bought several small cheap Radio Shack digital multi meters as well as some small hand held early conventional Triplett multi meters form work a long time ago.They never agree on the readings on voltage or Ohms except the same generation Tripletts meters with the same internal battery voltage being within 1/10 volt of each other shruggy Buy, beg, borrow or steal the good one once up grin
Re: Digital multimeter recommendations please [Re: OzHemi] #1812678
04/26/15 11:39 PM
04/26/15 11:39 PM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
I have a Simpson 260 that is older than all your Flukes. smirk Analog to be sure. But all voltages, resistances and current measurements are analog anyway with no +/- 1 of the last digit error of all digital meters. It is also easier to tune for maximum with a analog meter.
I have 7 of the meters Harbor Freight gives away. Disposable but can be in the back of all my vehicles with four spares. I blew up a very expensive Beckman digital meter when I arced over a high voltage circuit years ago. I gave up a lab grade meters for daily use. I know where to borrow one if I need it.
Craig
Re: Digital multimeter recommendations please [Re: A990] #1812680
04/26/15 11:39 PM
04/26/15 11:39 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
I picked this one up today, speaking of meters...just like a sickness, can't help it laugh2
Re: Digital multimeter recommendations please [Re: A990] #1812682
04/26/15 11:41 PM
04/26/15 11:41 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Revolting perhaps, but I had too.
Re: Digital multimeter recommendations please [Re: Alaskan_TA] #1812683
04/26/15 11:42 PM
04/26/15 11:42 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
You won't find any resistance from me...
Re: Digital multimeter recommendations please [Re: A990] #1812686
04/26/15 11:44 PM
04/26/15 11:44 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Time for some quiet meditation.
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
ohm
Re: Digital multimeter recommendations please [Re: A990] #1812687
04/26/15 11:44 PM
04/26/15 11:44 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I have a yellow harbor freight one. I don't really know what I'm doing with it, but like the continuity buzzer it has.
Re: Digital multimeter recommendations please [Re: A990] #1812693
04/26/15 11:49 PM
04/26/15 11:49 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Check on Ebay, you can find some good deals on used ones there. I have been using the same Blue-Point meter for 15 years until it got crushed. Got the same model on E-Bay that looked new for $50.
The only Carbs I care about are under the hood!
Re: Digital multimeter recommendations please [Re: denfireguy] #1812696
04/26/15 11:50 PM
04/26/15 11:50 PM
IN
ahy Offline
ahy  Offline
IN
I have a Radio Shack digital and has served me well for ~15 years. Not used daily. Don't know what the current ones are like but for occasional use, works fine.
Re: Digital multimeter recommendations please [Re: Alaskan_TA] #1812697
04/26/15 11:50 PM
04/26/15 11:50 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
ohm
...etc
You are lucky I have the capacity for all the puns.
Re: Digital multimeter recommendations please [Re: Cab_Burge] #1812704
04/26/15 11:54 PM
04/26/15 11:54 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Have an old Triplett 630 amoungst other things as well.. and my Fluke, just a model 25, so nothing too fancy.
Re: Digital multimeter recommendations please [Re: A990] #1812712
04/27/15 12:00 AM
04/27/15 12:00 AM
541 slobovia
A990 Offline OP
A990  Offline OP
541 slobovia
why am I not shocked at all this
Page 1 of 4 1 2 3 4
