electrical question #175665
12/26/08 09:26 PM
12/26/08 09:26 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
have a 69 charger R/T with stock harnesses ..wan't to convert to MP electronic ignition , & put the later type electronic voltage regulator in , plus the duel field alternator , would a 60 amp one be ok .or would it be too many amps , & start burning stuff up .
are there any good wiring diagrams ??
for this conversion ???
any help would be appreciated
also heard the orange box is rubbish ??
Re: electrical question [Re: A47] #175666
12/26/08 09:51 PM
12/26/08 09:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
To go with the newer alternator all you need to do is add one field wire from the alternator to the regulator. I would use a blue color. Get a new style regulator and plug pigtail. Your old original green field will go to the green on the new regulator pigtail and your original 12 volt blue feed will go to the other. You will also have to splice your added blue field wire to the blue pigtail splice. Thats basicly it.
Now you should bypass your ammeter [hook both wires togeather] and consider a voltmeter conversion to the OEM guage panel. You also should increase the size of the battery feed wire from the alternator and run it to the large stud on the starter relay. At that point you should install a large maxi fuse or fuse link.
If you buy a ignition conversion kit all the instructions will be there. If you chose to get your own box and distributor you can buy a ignition harness from Mancini Racing.
Some orange boxes fail some dont. You can always cary a used oem spare for safety.
Search the tech archives lots of info there.
Re: electrical question [Re: A47] #175667
12/27/08 10:05 AM
12/27/08 10:05 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
The second poster is correct. The following link may help you understand what he is talking about. Read and digest the information on the links on this page, and you will be more knowledgable than most on this subject.
http://www.madelectrical.com/electrical-tech.shtml
Re: electrical question [Re: NITROUSN] #175668
12/27/08 01:40 PM
12/27/08 01:40 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
thank you ! for the info & help Guys ! it has been greatly appreciated
happy new year
Re: electrical question ..... another question ????? [Re: A47] #175669
12/27/08 03:37 PM
12/27/08 03:37 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
another question ...fuseable links ... could you replace them with fuses in stead ... ?????????????????????/
Re: electrical question ..... another question ????? [Re: A47] #175670
12/27/08 03:51 PM
12/27/08 03:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Read what i told you..
Re: electrical question ..... another question ????? [Re: NITROUSN] #175671
12/27/08 04:17 PM
12/27/08 04:17 PM
Kirkland, Washington
Pacnorthcuda Offline
Is a "maxi fuse" some sort of slo-blow???
Re: electrical question ..... another question ????? [Re: Pacnorthcuda] #175672
12/27/08 04:26 PM
12/27/08 04:26 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Not that I am aware of. In this application the fuse is only for the alternator.
Re: electrical question ..... another question ????? [Re: NITROUSN] #175673
12/27/08 04:27 PM
12/27/08 04:27 PM
Got it, was wondering if there was a new trick out there...
Re: electrical question ..... another question ????? [Re: NITROUSN] #175674
12/27/08 04:39 PM
12/27/08 04:39 PM
under the hood
A47 Offline OP
A47  Offline OP
under the hood
damn i feel stupid now ... yes i read your post , but then spent a good hour reading the link & looking a charger wiring diagrams ..the forgot all about what you said
thanks a gain Pete the reminder to what you sugested & the link John
Re: electrical question ..... another question ????? [Re: Pacnorthcuda] #175675
12/27/08 11:07 PM
12/27/08 11:07 PM
N
NITROUSN Offline
NITROUSN  Offline
N
You can use a fuse link but it seems like most newer cars and trucks get away from them and use a fuse on the alternator.
Re: electrical question ..... another question ????? [Re: A47] #175676
12/27/08 11:59 PM
12/27/08 11:59 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
You can also run a circuit breaker. They have some nice high-amperage models in the car audio world. That's the route I'm going with, because you can simply reset it or open it as a suplemental anti-theft type power cut off.
