electrical question
#175665
12/26/08 09:26 PM
12/26/08 09:26 PM
Posts: 384 under the hood
A47
under the hood
have a 69 charger R/T with stock harnesses ..wan't to convert to MP electronic ignition , & put the later type electronic voltage regulator in , plus the duel field alternator , would a 60 amp one be ok .or would it be too many amps , & start burning stuff up . are there any good wiring diagrams ?? for this conversion ??? any help would be appreciated also heard the orange box is rubbish ??
Re: electrical question
[Re: A47]
#175666
12/26/08 09:51 PM
12/26/08 09:51 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
To go with the newer alternator all you need to do is add one field wire from the alternator to the regulator. I would use a blue color. Get a new style regulator and plug pigtail. Your old original green field will go to the green on the new regulator pigtail and your original 12 volt blue feed will go to the other. You will also have to splice your added blue field wire to the blue pigtail splice. Thats basicly it.
Now you should bypass your ammeter [hook both wires togeather] and consider a voltmeter conversion to the OEM guage panel. You also should increase the size of the battery feed wire from the alternator and run it to the large stud on the starter relay. At that point you should install a large maxi fuse or fuse link.
If you buy a ignition conversion kit all the instructions will be there. If you chose to get your own box and distributor you can buy a ignition harness from Mancini Racing.
Some orange boxes fail some dont. You can always cary a used oem spare for safety.
Search the tech archives lots of info there.
[Re: A47]
#175667
12/27/08 10:05 AM
12/27/08 10:05 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
The second poster is correct. The following link may help you understand what he is talking about. Read and digest the information on the links on this page, and you will be more knowledgable than most on this subject. http://www.madelectrical.com/electrical-tech.shtml
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: electrical question ..... another question ?????
[Re: A47]
#175676
12/27/08 11:59 PM
12/27/08 11:59 PM
jbc426
West Coast, USA
You can also run a circuit breaker. They have some nice high-amperage models in the car audio world. That's the route I'm going with, because you can simply reset it or open it as a suplemental anti-theft type power cut off.
