Block fill questions #1708861
12/10/14 03:24 AM
12/10/14 03:24 AM
Midland,Tx
wyldebill Offline OP
Midland,Tx
Hey guys, I have a couple of questions about block filling. How high would you fill, for a 400 block? This will be driven as well as a race engine. Will be taking this on drag week. How will this affect water and, or oil temp?
Re: Block fill questions [Re: wyldebill] #1708862
12/10/14 04:27 AM
12/10/14 04:27 AM
Finalnd, Perkele
jyrki Offline
jyrki  Offline
Finalnd, Perkele
I wouldn't fill much over the bottom of the freeze plugs unless you are going to use an oil cooler. I had one that was filled close to the top of the freeze plugs, and the oil got very hot in continuous driving loosing its viscocity.
Plynouth VIP '67 TT IC EFI
Re: Block fill questions [Re: wyldebill] #1708863
12/10/14 04:36 AM
12/10/14 04:36 AM
Why would you want to fill that block? I know a lot of racers that have used filled and then unfilled blocks after they found a good block that sonic tested okay. Why would you want to have two different temperatures zones in your cylinders? Especially on a car that will see a lot of road time If your block is thin buy a better block, no bandaids One thing to keep in mind on block fillers is all cement shrinks as it cures, even expensive commercial non shrinking cement BTW, I do have three brand new bottles of Moroso block filler if you want to buy some of them at a good price
Re: Block fill questions [Re: Cab_Burge] #1708864
12/10/14 11:28 AM
12/10/14 11:28 AM
NO advantage to a fill on street unit
Save that $$ for fuel
Just because it is in the magazines does not mean you should do it. No advantage --it is used to shore up thin castings and "bandaid" for stock blocks that will be stressed beyond common sense for a stock block---in these days of aftermarket blocks--their is just no reason to do it--got a thin cylinder in a race block you want to save?--OK
Ground through the water in a SBC while stroker grinding? well then ok..but doing it because you think it will make a stock block stronger?? Forget about it--and main cap bolts are fine too , not much need for studs in most cases--save that Loot!
Re: Block fill questions [Re: ] #1708865
12/10/14 12:14 PM
12/10/14 12:14 PM
Midland,Tx
Midland,Tx
i have not been a big fan of block filling. it seems to me that you would want the top of the cylinder the strongest, but your reinforce the bottem with concrete. thats why i am asking the question before i do it.
Re: Block fill questions [Re: wyldebill] #1708866
12/10/14 12:23 PM
12/10/14 12:23 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Actually the center of the cyl needs some help.. the
top and bottom have the steel.. the top has the deck..
I have filled 2 blocks.. I cracked a cyl wall on one
and water still ran into the cyl... that tells me
that due to shrinkage it pulled back from the wall
and thus it really didnt do anything except increase
the temp of the water and the oil... specially on a
street engine I wont fill it
Re: Block fill questions [Re: wyldebill] #1708867
12/10/14 12:27 PM
12/10/14 12:27 PM
Az
Crizila Offline
Crizila  Offline
Az
I would not fill if you are contemplating street driving. I run a 3/4 fill on my small block ( race only ) because I am pushing well over 600HP with a stock block - even though it sonic tested good. On mine, water temp is no longer an issue. With about a gallon less than stock capacity, the water goes through the rad more often. I never see over 190. Oil temp is another issue. One pass and it is in the 200 degree range. Still ok, but it gets up there pretty fast and I am sure it would continue to climb with street driving. Unless you know that the bottom end is your weak link, I would not use fill.
Fastest 300
Re: Block fill questions [Re: Crizila] #1708868
12/10/14 12:44 PM
12/10/14 12:44 PM
Midland,Tx
Midland,Tx
heat soak on the oil temp was my biggest concern. an aftermarket just isnt in the cards right now, or in the near future. unless someone knows of somwthing.
Re: Block fill questions [Re: wyldebill] #1708869
12/10/14 02:38 PM
12/10/14 02:38 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Rok Block is the only product to use. It has epoxy in it, so it does not shrink, and conforms and sticks way better.
http://www.competitionproducts.com/Rokbl...K/#.VIhxNdItCvE
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Block fill questions [Re: wyldebill] #1708870
12/10/14 02:42 PM
12/10/14 02:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Been beatin on my 72 400 block almost 13 years stock caps and no fill.............
Re: Block fill questions [Re: Thumperdart] #1708871
12/10/14 02:49 PM
12/10/14 02:49 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I can give you a filled one.....just don't expect it to circulate water ....don't go to high
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Block fill questions [Re: Eric] #1708872
12/10/14 03:01 PM
12/10/14 03:01 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Concrete is for in ground swimming pools not already over-weight race cars.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Block fill questions [Re: pittsburghracer] #1708873
12/10/14 03:20 PM
12/10/14 03:20 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I use hard block!
It has cast iron powder in it. It's magnetic if you need to chip it out lol
Don't go higher then middle of the freeze plugs. Much higher and you get into the head bolt hole boss's and you will cut off water flow.
Re: Block fill questions [Re: FastmOp] #1708874
12/10/14 03:50 PM
12/10/14 03:50 PM
PA.
"Little"John
"Little"John
PA.
I look at it this way. My 500 cubic inch engine lasted 275 passes running 8.60's- 9.0's. (440 block) In Pa weather that takes me 3 maybe 4 years before I finally cracked a block.( no fill, no girdle) It costs me about 400-500 dollars paid out to do prep work on a race block so that's cheap in my eyes. If you go fast enough with a stock block sooner or later its going to fail and I don't care what you do to it. Now I know some street guys are going to jump in and say but,but, but in my statement I said IF you go fast enough. Running 9.0's-10.0's with stock stroke, stock crank engines my cranks would have cracks in them every rebuild (3-4 years)but i never cracked a block. I got to the place where I would tear the engine down and not even check the crank for cracks. I would just throw it on the scrap pile. I broke one stock main cap before switching over to a set of 440source bilit caps. By the way the block that cracked never leaked a drop of water, ran a 8.62@155mph on its last pass, and the crack was found during Winter tear-down.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Block fill questions [Re: pittsburghracer] #1708875
12/10/14 06:47 PM
12/10/14 06:47 PM
Az
Crizila Offline
Crizila  Offline
Az
Bottom line ( IMO ) with block fill is temp control. If you can't control the oil and or water temp, the rest is a moot point - and you could very likely have problems on the street in this area, even with a 1/2 fill. Here is what a 3/4 fill looks like on a small block. Yes, the water still dose circulate.
Fastest 300
Re: Block fill questions [Re: wyldebill] #1708876
12/10/14 07:19 PM
12/10/14 07:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
One other thing about drag week... it always seems to
be HOT.. seems common to be near a 100* and they tend
to run you in some SLOW city traffic just to see how
the cars can handle it... for my DW junker I didnt
fill it .. it can get up to 210* running down the road
at 75 for a hour or so.. if I back it down 5-10 mph
it cools back to 180*
Re: Block fill questions [Re: MR_P_BODY] #1708877
12/10/14 09:03 PM
12/10/14 09:03 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
How many pounds will it take to the bottom of the soft plugs? HARD BLOK
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Block fill questions [Re: slippery440] #1708878
12/10/14 09:27 PM
12/10/14 09:27 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If I remember right it was 1/2 of the bucket of hard
block per side
Re: Block fill questions [Re: MR_P_BODY] #1708879
12/10/14 09:54 PM
12/10/14 09:54 PM
Midland,Tx
Midland,Tx
i pulled the plug on filling the block. if you'll notice im from west Texas. so heat is always an issue. we're sonic checking the block this weekend. if i have a thin cylinder, then ill address it. cap walk is a bigger concern at this point, and i think we have it handled. thanks guys.
Re: Block fill questions [Re: wyldebill] #1708880
12/11/14 12:48 AM
12/11/14 12:48 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Bill,
The 508 in the Barnyard Viper is a tall filled 440 (to the bottom of the water pump holes). It has completed two Drag Weeks. Water temp never gets over 190, oil temp usually 210-220. We have a small oil cooler on it, and it needs a bigger one, when we push it hard, oil temp climbs to 230-240, and pressure starts to drop, 10-15lbs less than normal, and we change the oil at the next track!
It was a race engine that got pressed into street duty, so far, so good.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
